Rate Check Results - SQ Details
After you have pressed the Check Rate button on the Main page, you can navigate to the SQ Details tab to view the service quantities that supplied to (or derived by) you rate. Please be aware that a rate can derive service quantities if there are register rules, service quantity rules or time-of-use mapping rate components.
Description of Page
The Rate Schedule and its description, the Revenue Class and its description and the Bill Period are displayed at the top.
The SQ details grid is a snapshot of the service quantities amassed from:
- The quantities input on the main page OR the quantities taken from the service quantity collection for the bill segment, if it was input on the main page.
- The SQ rules defined on the input rate.
- The register rules defined on the input rate.
The following information is displayed in the grid:
- UOM is the unit of measure of the service quantity.
- TOU is the time-of-use code of the service quantity.
- SQI is the service quantity identifier of the service quantity.
- Initial Service Quantity is the initial quantity amassed by the system before application of the rate's SQ rules.
- Billable Service Quantity is the service quantity that will be priced by the service agreement's rate. This amount differs from the initial service quantity when the rate's SQ rules manipulate consumption.
