Stock Location - Characteristics
The characteristics page contains information that describes miscellaneous information about the stock location. Open this page using and navigate to the Characteristics page.
Description of Page
Use the Characteristics collection to define miscellaneous information to be kept for stock locations. For example, a premise ID can be specified as a characteristic to identify the address of a stock location.
You can only choose characteristic types defined as permissible on the stock location record. Refer to Setting Up Characteristic Types & Their Values for more information.
To modify a characteristic, simply move to a field and change its value. To add a new characteristic, click + to insert a row, then fill in the information for each field. The following fields display:
Effective Date Define the date on which the characteristic becomes effective. The effective date defaults from the Installation Record.
Characteristic Type Indicate the type of characteristic.
Characteristic Value Indicate the value of the characteristic.
