Defining Context-Sensitive Zones
A context-sensitive zone allows you to associate a zone with a specific user-interface transaction. A context-sensitive zone appears at the top of the Sidebar when a user accesses a page for which the zone is specified as the context.
CAUTION:
Make sure that the zone is appropriate for the transaction on which you are specifying it.
Select Admin > Context Sensitive Zone to maintain context-sensitive zones.
Description of Page
The Navigation Key is a unique identifier of a tab page within the system. Owner indicates if this navigation key is owned by the base product or by your implementation (Customer Modification).
CAUTION:
Important! When introducing a new context sensitive zone, carefully consider its naming convention. Refer to System Data Naming Convention for more information.
The grid contains the list of context-sensitive zones and the sequence in which they appear in the sidebar for the selected navigation key. The grid contains the following fields:
  • Zone is the name of the zone to display in the Sidebar.
  • Sequence is the sequence in which the zone is displayed (if multiple context-sensitive zones are defined).
  • Owner indicates if this context sensitive zone is owned by the base product or by your implementation (Customer Modification).
Where Used
A context-sensitive zone displays at the top of the Sidebar whenever a user accesses the transaction for with the zone is specified.
