Javadocs Viewer
The system provides a Javadocs viewer and a Groovy Javadocs viewer, which are interactive tools that allows you to browse Java documentation files (Javadocs) for Java classes that execute on the application server. For information about how to use Javadocs and navigate within the viewer, refer to Javadocs help.
Javadocs
To launch the Javadocs viewer, open open Admin > Implementation Tools > Javadocs.
Proprietary Java Classes. A small number of Java classes have been suppressed due to their proprietary nature.
Additionally, when viewing a record that references a Java program in the algorithm type page, the batch control page or the FK reference page, an icon adjacent to Java program allows you to view the Javadocs for that program.
Groovy Javadocs
The Groovy Javadocs viewer includes the Java classes that are accessible to Groovy code within scripts. Launch this viewer using the 'View Groovy Javadocs' action on the script page.
