Match Event Cancellation Reason Setup
The number of match event cancellation reasons that you will need is dependent on the number of ways your organization can justify the cancellation of a match event. At a minimum, you will probably need the following match event cancellation reasons:
  • FT Cancellation. This cancel reason should be referenced on the Customer Class FT Freeze algorithm that is responsible for canceling match events when one of its financial transactions is cancelled.
  • Incorrect Allocation. This cancel reason should be specified by users when they cancel match events that were created by the system erroneously.
