Setting Up Manufacturers & Their Models
When you set up a meter (or an item) you must define the manufacturer and model number of the meter / item. To define a manufacturer and its models, open
Description of Page
Enter an easily recognizable Manufacturer and Description for the manufacturer.
Enter a Model and Description for every model supplied by the manufacturer. Enter the Service Type with which the model is associated. Refer to Setting Up Service Types for more information.
If the model is associated with a meter, turn on Use On Meter. If the model is associated with an item, turn on Use On Item.
