Designing Your TOU Groups
To further aid in designing time of use mapping, the TOU Group enables you to group together all the time of use codes that are used in a single map. In our above example, we will have two TOU Groups because the active and reactive energy quantities are mapped to different sets of time periods. You must also decide if you want to use a sequence number to define the relative order of a TOU within a TOU group.
Refer to Grouping of TOU Codes for more information.
TOU Group |
Description |
Time of Use |
TOU Sequence |
4PARTS |
Group for a 4-part map including On and Off Peak for Winter and Summer. |
ONWIN |
0 |
OFFWIN |
0 |
ONSUM |
0 |
OFFSUM |
0 |
2PARTS |
Group for a 2-part map including On and Off Peak for Summer |
ONSUM |
0 |
OFFSUM |
0 |
CURTAIL |
Curtailment group, contains only one time of use |
CURTAIL |
0 |
