Defining an SA Type for Miscellaneous Transactions
Does your membership require a service agreement to support miscellaneous transactions? If so, you need to consider the SA type to use for this service agreement. This SA type should be marked as not billable.
If you choose to use the order transaction to set up the membership, this SA type must be defined on the algorithm that creates the membership.
It is possible that you may require a start option for this SA type, for example if you want to define a characteristic for service agreements of this type.
