Setting up master data extracts involves the following steps:
Add audit algorithms on the Service Agreement, Account,
Person, Service Point, Premise, SP/Meter History and Meter maintenance
objects.
Add the Generic Change Data Capture algorithm as an
audit algorithm on the Service Agreement, Service Point, and SP/Meter
History maintenance objects.
Add the Account Change Data Capture (SA-Based) - Include
Reactivated SAs algorithm as an audit algorithm on the Account maintenance
object.
Add the Person Change Data Capture (SA-Based) - Include
Reactivated SAs algorithm as an audit algorithm on the Person maintenance
object.
Add the Premise Change Data Capture (SA-Based) algorithm
as an audit algorithm on the Premise maintenance object.
Add the Meter Change Data Capture (SP/Meter History-Based)
algorithm as an audit algorithm on the Meter maintenance object.
Add the DataConnect synchronization request business objects
as Sync Request BO options on the Service Agreement, Service Point
and SP/Meter History maintenance objects.
Execute initial load batch processes related to service
agreements and service points.
Once the initial load synchronization has been executed,
changes to service agreements, accounts, persons, service points,
premises, SP/Meter History records or meters will trigger the creation
of new synchronization requests and resulting extraction files.
Execute the sync request monitor process.
Execute the extract batch processes related to service
