How Customer Contacts Are Created
You can add a Customer Contact at any time using either of the following methods:
- Use the customer contact maintenance page.
- Use the Customer Contact Zone on the dashboard.
When customer contacts are created through the Customer Contact dashboard zone, the system populates person, account, and/or premise based on context.
In addition to manually adding customer contacts, your implementation team can set up plug-in algorithms that create customer contacts when certain events transpire. For example, you can plug-in an algorithm on the customer class object that creates a customer contact whenever an order is completed. Because the number and type of plug-ins can be customized for your implementation, we cannot provide a concise list of all such algorithms.
In addition to the above, a variety of events can trigger the creation of a customer contact. Refer to Customer Contacts Are Used To Trigger Letters for the details.
