Premise Context Zone
Along with the Customer Context Zone, the Premise Context Zone is an alternative to the Current Context Zone.
The zone contains a tree that
shows the various objects linked to the premise in context as well
as any additional premise(s) associated to the account in context.
You can use this tree to both view high-level information about these
objects and to transfer to the respective page in which an object
is maintained.
Note: Refer to the C1-PremiseTree tree definition for more information about the premise tree node definitions
and hierarchy.
Moving Service options are used
to initiate start, stop, or transfer service requests.
Note: The base
package delivers this zone configured on the Dashboard Portal but
with the Display turned off by default. To enable the Premise
Context zone, navigate to your User -
Portal Preferences, open the Dashboard portal settings and
turn on the Display option for the Premise Context zone.
