High / Very High
If the reading's consumption is greater than the high limit consumption, compute the high percentage =
((Reading's consumption - High limit consumption) / High limit consumption) * 100, round to the nearest integer
If the high percentage is greater than or equal to the input VERY-HIGH-PERCENTAGE-CUTOFF, the reading is considered "very high", otherwise it is considered "high".
