Data is Stored in the Base Time Zone
With data stored at an interval level, provisions need to be made to cater for data captured from other time zones.
- On the installation record, you indicate the base time zone for your company data.
- ALL data must be stored in Standard time for this base time zone.
In order to help interfaces to adjust data received from a different time zone, you may store the customer's time zone on its Premise. The interface may be written to check the premise's time zone, compare it to the base time zone, and shift the data accordingly.
Fastpath:
Refer to Designing Your Time Options for more information.
