TOU Data Set Key
When a system-generated key value is assigned to a record, you need to also store the key value in a key table that corresponds to the record's database table. The name of this table is CI_TOU_DATA_SET_K. The following table describes each column on this table.
Column Name |
Length |
Req'd |
Data Type |
Comments |
TOU_DATA_SET_ID |
12 |
Y |
A/N |
This should be your newly created TOU Data Set ID from above. |
ENV_ID |
6 |
Y |
N |
This is the environment id defined on the installation options. |
