Eligibility Rules For Package 1
Package 1 (the senior package) in our example campaign has the following eligibility rules:
- Customer class = Residential
- Division = California
- Birth date equates to that of a senior citizen
These rules require only one eligibility group on the package. It would looks as follows:
Group No. |
Group Description |
If Group is TRUE |
If Group is FALSE |
1 |
Residential, Calif, Senior |
Eligible |
Ineligible |
The following criteria will be required for this group:
Group 1: Residential, Calif, Senior |
Seq |
Field to Compare |
Comparison Method |
If TRUE |
If FALSE |
If Insufficient Data |
10 |
Algorithm: retrieve order's customer class |
= R |
Check next condition |
Group is false |
Group is false |
20 |
Algorithm: retrieve order's division |
= CA |
Group is false |
Group is false |
30 |
Misc Field On Order: Date of Birth |
Algorithm: True if senior |
Group is true |
Group is false |
Group is false |
