A Calculation Rule with a Service Quantity Comparison
Customer is a low income customer
The customer has used more than 1,000 kWh during the bill period
These rules will look as follows:
Seq |
Field to Compare |
Comparison Method |
If TRUE |
If FALSE |
If Insufficient Data |
10 |
Main person characteristic: Characteristic type = Low income indicator |
= YES |
Check next condition |
Do Not Apply Rule |
Do Not Apply Rule |
20 |
SQ value: UOM = KWH |
>= 1,000 |
Apply Rule |
Do Not Apply Rule |
Error |
The criteria are similar - they retrieve a value and compare it to something:
Field to Compare. We indicate that the value of the Low Income Indicator characteristic is kept on the main person linked to the account should be retrieved. We assumed that this characteristic type has values of YES and NO.
Comparison Method and Results. We indicate that if the person has a characteristic value of YES, then we should check the next condition; otherwise, we indicate if the eligibility rule is false or there is insufficient data, the calculation rule is skipped.
Field to Compare. We indicate the service quantity (SQ) that holds the total amount of KWH that should be retrieved.
Comparison Method and Results. We simply compare the value to 1,000. If the SQ is greater than or equal to 1000, the eligibility rule is True and the calculation rule is applied. If the SQ is less than 1000, the eligibility rule is false and the calculation rule is skipped. If there is insufficient data, there is an error generated.
