Calculated Minimum Charges
The following table illustrates the rate components necessary to levy a simple rate that contains the following charges:
- First 300 kilowatt-hours at $0.0382 per kWh.
- Remaining kilowatt-hours at $0.0673 per kWh.
- Minimum charge of $0.15 per day.
- State Tax at the prevailing rate (this tax is a percentage of a dollar value).
- County Use Tax at the prevailing rate (this tax is an amount per kilowatt-hour).
Seq # |
RC Type |
Value Type |
Value |
Bill Factor |
Item Type |
UOM/TOU/SQI |
Step Range |
Cross Reference |
Calc Only |
Result Type |
30 |
Service Quantity |
Unit Rate |
0.0382 |
KWH |
0 to 300 |
N |
40 |
Service Quantity |
Unit Rate |
0.0673 |
KWH |
300 to infinity |
N |
50 |
Summary |
30, 40 |
N |
52 |
Service Quantity |
Unit Rate |
.15 |
DAYS |
Y |
Charge |
54 |
Minimum |
Charge |
52 |
30, 40 |
N |
60 |
Apply To |
Percent |
STTAX |
30, 40, 54 |
N |
70 |
Apply To |
Unit Rate |
COUNTYTAX |
30, 40 |
N |
