Defining Measured Quantity Manipulation Rules
This section describes when and how you have the system manipulate measured consumption before it is applied to the charges in a rate.
Warning:
Quantity manipulation rules exist to support calculations performed by rate components. This means that you must design your rate components before you can design your quantity manipulation rules. We strongly recommend that you design "on paper" how every rate's rate components looks before you attempt to set up these rules.
