How To Set Up Apply To Rate Components
There are no special additional fields on this page available for setting up an Apply To rate component. The following information will help you determine how to set up your Apply To rate components.
Select a Value Type of Percent if the type of charge is a percent of the dollar value of previously calculated rate components. If the amount being charged is an amount per some unit of consumption, select the Value Type of Unit Rate. This field will be disabled when the rate component references other rate components.
Refer to Rate Component - Main Information for information about defining the Value Source.
Enter the verbiage to appear on the customer's bill in Description On Bill and turn on the Print switch. Refer to How to use Description on Bill for more information about these fields.
Move to the Cross Reference window to define the rate components to which the charge will be applied.
Move to the GL Distribution window to define how to book moneys associated with this rate component in the general ledger.
