Steps Performed at Installation Time
Refer to the Installation Guide or Optional Products Installation Guide for instructions for setting up and configuring your product and reporting tool to use the sample reports provided with the system. The following steps are described there.
- Setting up the stored procedures used by the sample reports.
- Defining the company title and logo used by the sample reports. Note the company name used as a title in the sample reports is defined as a message on the installation options.
- Defining a user for integration with your product.
- Publishing the sample reports in BI Publisher.
Contact your system administrator to verify that the above steps have occurred.
