Forcing a Check In or Restore
You can force a check in if an object is checked out by another user and that person is not available to check it in.
You must have proper access rights to force a check in or restore.
- Go to the object that is checked out by another user.
- Select Force Check In or Force Restore in the Revision Control zone.
