Interval Data Set
You must create a data set for each batch of records being uploaded in the system for the same profile. The name of this table is CI_INTV_DATA_SET. The following table describes each column on this table.
Column Name |
Length |
Req'd |
Data Type |
Comments |
INTV_DATA_SET_ID |
12 |
Y |
A/N |
This is a unique key. This key is referenced on the interval data record. It's suggested that this key is built as follows:
INTV_PF_ID |
12 |
N |
A/N |
This is a foreign key reference to the interval profile to which this set is linked. It is required if an external ID is not specified. |
INTV_DS_EXT_ID |
60 |
N |
A/N |
This is the external identifier of the profile to which this data belongs. It is required if profile ID is not specified. |
SET_DTTM |
26 |
Y |
DateTime |
This is the date/time that the data set was received. This must be populated with the current date/time. This is considered a server date and follows the seasonal time shifting as defined on the base time zone. Refer to Seasonal Time Shifts for more information. Refer to Algorithms Find the Most Up-To-Date Data for information about why this date/time is important. |
SET_STATUS_FLG |
2 |
Y |
A/N |
Set this value based on whether it will be validated in the system. Set to P for Pending if the profile ID is blank or if the profile's profile type indicates a validation algorithm. Set to C for Complete if the data should not go through any further validation. Refer to Life Cycle of Interval Profile Data for more information |
