Eligibility Rules For Package 3
Package 3 (the single-family / gas heat package) in our example campaign has the following eligibility rules:
- Customer class = Residential
- Division = California
- Birth date does not equate to that of a senior citizen
- Lives in a single-family home
- House is heated with gas
These rules require only one eligibility group on the package. It would looks as follows:
Group No. |
Group Description |
If Group is TRUE |
If Group is FALSE |
1 |
Residential, Calif, Non Senior, Single Family, Gas Heat |
Eligible |
Ineligible |
The following criteria will be required for this group:
Group 1: Residential, Calif, Non Senior, Single Family, Gas Heat |
Seq |
Field to Compare |
Comparison Method |
If TRUE |
If FALSE |
If Insufficient Data |
10 |
Algorithm: retrieve order's customer class |
= R |
Check next condition |
Group is false |
Group is false |
20 |
Algorithm: retrieve order's division |
= CA |
Group is false |
Group is false |
30 |
Misc Field On Order: Date of Birth |
Algorithm: True if senior |
Group is false |
Group is false |
40 |
Misc Field On Order: Type of Residence |
= S (single family home) |
Group is false |
Group is false |
50 |
Misc Field On Order: Type of Heat |
= G (gas) |
Group is true |
Group is false |
Group is false |
