Web Service Catalog Master Configuration
The Service Catalog Configuration (master configuration) record defines several system wide settings related to integrating with the service catalog.
It includes configuration for the WSDL base URL for the SOAP catalog. Note that this element supports the functionality described in Referencing URIs. Note that for the REST catalog, the system will use the URL defined in the substitution variable F1_OPEN_API_BASE_URL
The subordinate server section is no longer applicable and will be removed in a future release.
For more information about specific fields in the master configuration, refer to the embedded help.
