Monitoring from Integration
Use any of the following to monitor the integration:
Monitoring Using WebLogic SOA Enterprise Manager
Perform the following steps to monitor through WebLogic SOA Enterprise Manager:
1. Login to the WebLogic SOA Server Enterprise Manager, and then navigate to SOA > SOA-Infra > CCB-EBS.
All composite processes deployed for integration are available under the partition CCB-EBS.
2. Select the appropriate process to list all the instances for the processes sorted by time of execution.
3. Click the appropriate process instance and it displays the flow for the process. The composite flow lists all activities in the process instance.
Monitoring Using WebLogic Logs
Login to the machine where SOA server is installed. The SOA logs are stored in:
<WebLogic installation folder>/user_projects/domains/<SOA Domain name>/servers/<SOA Server name>/logs
Example: /Oracle/Middleware/Oracle_Home/user_projects/domains/soa_domain/servers/soa_server1/logs
Monitoring Using Integration Error Store Table
Errors occurring during the integration such as when financial transactions are extracted or summarized, when data formats are translated, or when data is inserted into one of the edge applications are logged and reported by the integration product in the INTEGRATION_ERROR_STORE table.
Use standard database (SQL based) tools to view the error information in the table if necessary, however the e-mail notification you receive must include all of the information necessary to investigate and correct the error.
If errors occur during the extraction or load process for any of the integration points, the system logs an error in INTEGRATION_ERROR_STORE. Business data is stored in the ERROR_MESSAGE field of the table, and the information is also included in the notification email.
The following sections indicate where to locate error messages and logged error data in each of the integration point:
GL Integration Point
If errors occur during the extraction of Financial Transactions from Oracle Utilities Customer Care and Billing tables or during loading these transactions into Oracle E- Business Suite Financials for General Ledger and Accounts Payable GL_INTERFACE table, integration process inserts the error into INTEGRATION_ERROR_STORE.
The following business data is stored in the ERROR_MESSAGE field of INTEGRATION_ERROR_STORE. This information is included in the notification email.
The GL integration point utilizes set based processing. If there is an error, with any part of the batch, the entire batch is rejected.
AP Request Integration Point
If errors occur during the extraction of Financial Transactions from Oracle Utilities Customer Care and Billing tables or during loading these transactions into Oracle E- Business Suite Financials for General Ledger and Accounts Payable Invoice Interface tables, BPEL inserts the error into INTEGRATION_ERROR_STORE.
The following business data is stored in the ERROR_MESSAGE field of INTEGRATION_ERROR_STORE. This information is included in the notification email:
AP Data Integration Point
