Service Configurations
Service Configuration properties are specific to SOA composites. These are used to make changes in specific composite behavior.
Service Name
Property Name
Default / Shipped Value
or System ID of Initiating System
Description
OUCCBOUNMSCustomerDataSyncReqEBF
Default.SystemID
OU_CCB_01
Initiating system ID.
Extension.PreXformCCBtoNMS
false
If set to true, the pre transformation extension service is invoked.
Extension.PostXformCCBtoNMS
false
If set to true, the post transformation extension service is invoked.
Extension.CustomXformItemCCBtoNMS
false
If set to true, the custom transformation for Item is invoked.
BusinessError.NotificationFlag
true
If set to true, the business error notification is sent via email.
TechnicalError.NotificationFlag
true
If set to true, the technical error notification is sent via email.
Comments.NoItemInfoMapping
Synchronization of item
information is not supported.
These comments are used to store a clearer error message in the integration error table when an error is encountered when a message with item information is sent from CCB, but no customization is enabled in the integration layer.
Comments.NoMeterandItemMapping
Meter or item information is missing.
These comments are used to store a clearer error message in the integration error table when an error is encountered when a message with no meter or item information is sent from CCB but no customization is enabled in the integration layer.
OUCCBOUNMSTroubleCallInterfaceEBF
Default.SystemID
OU_CCB_01
False
False
NMS.CCBCallSourceID
2
Define unique call source ID for CCB.
• This CCB call source ID indicates that the trouble call was created in CCB.
• This will also ensure that the external ID in the trouble calls table will have a unique value. NMS will prefix the call source ID to the external ID coming from CCB.
CCB.LocationType.StreetIntersection
C1IS
CCB uses the location type to determine whether a street intersection or street segment was populated for the location of a fuzzy call.
This is the CCB Location Type value for Street Segment.
Location Type coming from CCB is not mapped to NMS.
It is only used by the integration for the mapping of the cross street or block number.
CCB.LocationType.StreetSegment
C1SS
This is the CCB Location Type value for Street Intersection.
false
false
OUCCBOUNMSJobHistoryQuery
Default.SystemID
OU_CCB_01
false
false
Extension.PreXformNMStoCCB
false
Extension.PostXformNMStoCCB
false
NMS.NumberOfDaysOfHistory
60
Define the Number of Days Of Job History to return.
true
TechnicalError.Notificati onFlag
true
OUCCBOUNMSTroubleCallsQueryEBF
Default.SystemID
OU_CCB_01
false
false
false
false
60
Define the Number of Days Of Call History to return
BusinessError.Notificati onFlag
true
true
OUCCBOUNMSPlannedOutagesQueryEBF
Default.SystemID
OU_CCB_01
false
false
false
false
10
Define the Number of Days Of Planned Outages to return.
true
true
