Oracle Utilities Service Order Management Inbound Request Message | DVM Mapping | Comments | ||||
Element Name | Parent Element | Type | DVM | Oracle Field Service Column | Oracle Utilities Service Order Management Column | |
X1-RequestAdminData | OutermostTag | |||||
input | Group | |||||
languageCd | input | Field | SOMOFSC_ ConfigProps | PropertyName | Value | Hard code the property name as "som.adminsync.languagecode" |
table | input | Group | ||||
tableList | table | Group | ||||
tableName | tableList | Field | Hard code the tablename with "CI_PREM_TYPE" | |||
tableName | tableList | Field | Hard code the tablename with "D1_SVC_TYPE" | |||
standardLookup | input | Group | ||||
standardLookupList | standardLookup | Group | ||||
lookupField | standardLookupList | Field | Hard code the lookupField with "DISCONN_LOC_FLG" | |||
extendableLookup | input | Group | ||||
extendableLookupList | extendableLookup | Group | ||||
extendableLookupBO | extendableLookupList | Field | Hard code the extendable look up BO with "D1-SPInstructionLookup" | |||
extendableLookupBO | extendableLookupList | Field | Hard code the extendable look up BO with "D1-SPWarningLookup" | |||
extendableLookupBO | extendableLookupList | Field | Hard code the extendable look up BO with "D1-FieldTaskTypeLookup" | |||
Mappings for Getting Activity, Device and Register Admin Data from Oracle Utilities Customer Cloud Service | ||||||
tableName | tableList | Field | Hard code the tablename with "CI_CC_TYPE" | |||
tableName | tableList | Field | Hard code the tablename with "D1_UOM" | |||
tableName | tableList | Field | Hard code the tablename with "D1_TOU" | |||
tableName | tableList | Field | Hard code the tablename with "D1_SQI" | |||
tableName | tableList | Field | Hard code the tablename with "D1_DVC_TYPE" | |||
tableName | tableList | Field | Hard code the tablename with "D1_DVC_CFG_TYPE" | |||
tableName | tableList | Field | Hard code the tablename with "D1_SPR" | |||
tableName | tableList | Field | Hard code the tablename with "D1_MANUFACTURER" | |||
extendableLookupBO | extendableLookupList | Field | Hard code the extendable look up BO with "D1-FARemarkTypeLookup" | |||
extendableLookupBO | extendableLookupList | Field | Hard code the extendable look up BO with "D1-CancelReasonLookup" |
Oracle Utilities Service Order Management Response | Oracle Field Service Enum Request | DVM Mapping | Comments | |||||
Element Name | Parent Element | Element Name | Parent Element | Type | DVM | Oracle Field Service Column | Oracle Utilities Service Order Management Column | |
Label | Template Parameters | outermosttag | Gets the Sp property label from "SOMOFSC_Sync_ServicePointData" look up and assign it to the element | |||||
Request Wrapper | ||||||||
Items | Request Wrapper | List | ||||||
code | /standard LookupList/codeDescription List | Label | Items | Field | ||||
Active | Items | Hardcode as "true" | ||||||
translations | Items | List | ||||||
language | translations | SOM_ Language Code | OFSC_ LanguageCode | SOM_ LanguageCode | ||||
description | /standardLookup List/codeDescription List | name | translations | Field |
code | codeDescription List | Label | Template Parameters | outermosttag | SOMOFSC_ActivityType | OFSC_ActivityType | SOM_ TaskType | |
code | codeDescription List | Label | Request Wrapper | SOMOFSC_ActivityType | OFSC_ActivityType | SOM_ TaskType | ||
description | codeDescription List | Name | Request Wrapper | |||||
Active | Request Wrapper | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "activityType.active" | |||
Group Label | Request Wrapper | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "groupLabel" | |||
Default Duration | Request Wrapper | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "duration" | |||
Time Slots | Request Wrapper | List | ||||||
Label | Time Slots | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "timeslots.label" | |||
Colors | Request Wrapper | |||||||
Pending | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.pending" | |||
Started | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.started" | |||
Suspended | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.suspended" | |||
Cancelled | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.cancelled" | |||
Notdone | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.notdone" | |||
Not Ordered | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.notOrdered" | |||
Warning | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.warning" | |||
Completed | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.completed" | |||
Features | Request Wrapper | |||||||
Is Teamwork Available | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.isTeamworkAvailable" | |||
Is Segmenting Enabled | Features | Hard code the value as "false" | ||||||
Allow Move Between Resources | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowMoveBetweenResources" | |||
Allow Creation In Buckets | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowCreationInBuckets" | |||
Allow Reschedule | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowReschedule" | |||
Support Of Not Ordered Activities | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfNotOrderedActivities" | |||
Allow Non Scheduled | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowNonScheduled" | |||
Support Of Work Zones | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfWorkZones" | |||
Support Of Work Skills | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfWorkSkills" | |||
Support Of Time Slots | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfTimeSlots" | |||
Support Of Inventory | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfInventory" | |||
Support Of Links | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfLinks" | |||
Support Of Preferred Resources | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfPreferredResources" | |||
Allow Repeating Activities | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowRepeatingActivities" | |||
Calculate Travel | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.calculateTravel" | |||
Allow To Search | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowToSearch" | |||
Allow To Create From Incoming Interface | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowToCreateFromIncomingInterface" | |||
Calculate Delivery Window | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.calculateDeliveryWindow" | |||
Sla And Service Window Use Customer Time Zone | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.slaAndServiceWindowUseCustomerTimeZone" | |||
Support Of Required Inventory | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfRequiredInventory" | |||
Disable Location Tracking | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.disableLocationTracking" | |||
language | translations | SOM_LanguageCode | OFSC_LanguageCode | SOM_LanguageCode | ||||
description | codeDescription List | name | translations | Field |
Label | Template Parameters | outermosttag | Gets the activity data property label from "SOMOFSC_Sync_ActivityData" look up and assign it to the element | |||||
code | /standardLookup List/code DescriptionList | Label | Items | Field | ||||
language | translations | SOM_ LanguageCode | OFSC_ LanguageCode | SOM_ LanguageCode | ||||
description | /standardLookup List/code DescriptionList | name | translations | Field |
Device Type Mappings | ||||||||
Label | Template Parameters | outermosttag | Gets the Device Type property label from “SOMOFSC_Sync_DeviceTypesData” look up and assign it to the element | |||||
code | codeDescription List | Label | Items | Field | ||||
description | codeDescription List | name | translations | Field | ||||
Device Configuration Type Mappings | ||||||||
Label | Template Parameters | outermosttag | Gets the Device Configuration type property label from "SOMOFSC_Sync_DeviceConfigurationData" look up and assign it to the element | |||||
Device Manufacturer Mappings | ||||||||
Label | Template Parameters | outermosttag | Gets the Device Manufacturer property label from "SOMOFSC_Sync_DeviceManufacturerData" look up and assign it to the element | |||||
Device Model Mappings | ||||||||
Label | Template Parameters | outermosttag | Gets the Device Model property label from "SOMOFSC_Sync_DeviceModelData" look up and assign it to the element | |||||
Device Head End Mappings | ||||||||
Label | Template Parameters | outermosttag | Gets the Device Head End property label from "SOMOFSC_Sync_DeviceHeadEndSystemData" look up and assign it to the element | |||||
Register UOM Mappings | ||||||||
Label | Template Parameters | outermosttag | Gets the Register UOM property label from "SOMOFSC_Sync_RegisterUOMData" look up and assign it to the element | |||||
Register SQI Mappings | ||||||||
Label | Template Parameters | outermosttag | Gets the Register UOM property label from "SOMOFSC_Sync_RegisterSQIData" look up and assign it to the element | |||||
Register TOU Mappings | ||||||||
Label | Template Parameters | outermosttag | Gets the Register TOU property label from "SOMOFSC_Sync_RegisterTOUData" look up and assign it to the element | |||||
