Oracle Utilities Service Order Management Request Message | Oracle Field Service Request Message (Activity Booking Options) | DVM Mapping | Comments | ||||||
Element Name | Parent Element | Type | Element Name | Parent Element | Type | DVM | Oracle Utilities Service Order Management Column | Oracle Field Service Column | |
sendDetail | sendDetail | outermosttag | QueryParameters | outermosttag | |||||
startDateTime | sendDetail | dates | QueryParameters | Concat start date and end date and take only substring from 1,10 Use comma as delimeter | |||||
endDateTime | sendDetail | dates | QueryParameters | ||||||
postal | sendDetail | postalCode | QueryParameters | ||||||
criteria | sendDetail | ||||||||
appointmentBookingGroup | sendDetail | ||||||||
maxAppointmentWindowCount | sendDetail | ||||||||
maxCostUnits | sendDetail | ||||||||
timeZone | sendDetail | ||||||||
taskType | sendDetail | activityType | QueryParameters | string | SOMOFSC_ActivityType.dvm | SOM_ActivityType | OFSC_ActivityType | ||
serviceArea | sendDetail | ||||||||
geocodeLatitude | sendDetail | ||||||||
geocodeLongitude | sendDetail | ||||||||
duration | sendDetail | ||||||||
address1 | sendDetail | ||||||||
address2 | sendDetail | ||||||||
address3 | sendDetail | ||||||||
address4 | sendDetail | ||||||||
crossStreet | sendDetail | ||||||||
city | sendDetail | ||||||||
stateProvince | sendDetail | ||||||||
suburb | sendDetail | ||||||||
postal | sendDetail | postalCode | QueryParameters | string | |||||
country | sendDetail | ||||||||
matchQuality | sendDetail | ||||||||
siteDelay | sendDetail | ||||||||
hostExternalId | sendDetail |
Oracle Field Service Response Message (Activity Booking Options) | Oracle Utilities Service Order Management Response | DVM Mapping | Comments | ||||||
activityBookingOptions | responseDetail | outermosttag | |||||||
dates | activityBookingOptions | List | |||||||
areas | dates | List | |||||||
timeslots | areas | List | appointmentBookingsList | responseDetail | list | ||||
label | timeslots | string | shiftId | appointmentBookingsList | string | ||||
date | dates | arrivalDateTime | appointmentBookingsList | OFSCSOM_Appt_Timeslots | SOM_TimeSlots | OFSC_TimeSlots | Concat date '-' with the value coming from Dvm Lookup dvm with 'label' value and use only start time Once you extract the start time, translate to the desired format HH:MM:SS Use SOMOFSC_Appt_StartTime extension library function | ||
date | dates | completionDateTime | appointmentBookingsList | OFSCSOM_Appt_ Timeslots | SOM_TimeSlots | OFSC_TimeSlots | Concat date '-' with the value coming from Dvm Lookup dvm with label value and use only end time Use SOMOFSC_Appt_EndTime extension library function | ||
rank | appointmentBookingsList | Add position() function in the mappin | |||||||
remainingQuota | timeslots | units | appointmentBookingsList | ||||||
date | dates | appointmentWindowDateTime | appointmentBookingsList | OFSCSOM_Appt_ Timeslots | SOM_TimeSlots | OFSC_TimeSlots | Concat date '- with the value coming from Dvm Lookup dvm with label value and use only start time Use SOMOFSC_Appt_StartTime extension library function | ||
date | dates | appointmentWindowDuration | appointmentBookingsList | OFSCSOM_Appt_ Timeslots | OFSC_TimeSlots | Duration_InSeconds | Map the value comes from Dvm | ||
action | appointmentBookingsList | ||||||||
messageText | responseDetail | ||||||||
messageCategory | responseDetail | ||||||||
messageNumber | responseDetail | ||||||||
messageParameters | responseDetail |
Oracle Integration for Cloud Global Fault | Oracle Utilities Service Order Management Response Message | ||||
fault | OutermostTag | responseDetail | OutermostTag | ||
details | fault | String | |||
appointmentBookingsList | responseDetail | ||||
shiftId | appointmentBookingsList | ||||
arrivalDateTime | appointmentBookingsList | ||||
completionDateTime | appointmentBookingsList | ||||
rank | appointmentBookingsList | ||||
appointmentWindowDateTime | appointmentBookingsList | ||||
appointmentWindowDuration | appointmentBookingsList | ||||
reason | fault | String | messageText | responseDetail | |
messageParameters | responseDetail | ||||
fault | responseDetail | ||||
errorCode | fault | String | faultCode | fault | |
faultString | fault | ||||
faultActor | fault | ||||
details |
Oracle Integration for Cloud Global Fault | Oracle Utilities Service Order Management Request Message | ||||
appointmentBookingsList | responseDetail | List | |||
details |
