Oracle Utilities Service Order Management Inbound Request Message | DVM Mapping | Comments | ||||
Element Name | Parent Element | Type | DVM | Oracle Field Service Column | Oracle Utilities Service Order Management Column | |
X1-RequestAdminData | OutermostTag | |||||
input | Group | |||||
languageCd | input | Field | SOMOFSC_ConfigProps | PropertyName | Value | Hard code the property name as "som.adminsync.languagecode" |
table | input | Group | ||||
tableList | table | Group | ||||
tableName | tableList | Field | Hard code the tablename with "CI_PREM_TYPE" | |||
tableName | tableList | Field | Hard code the tablename with "D1_SVC_TYPE" | |||
standardLookup | input | Group | ||||
standardLookupList | standardLookup | Group | ||||
lookupField | standardLookupList | Field | Hard code the lookupField with "DISCONN_LOC_FLG" | |||
extendableLookup | input | Group | ||||
extendableLookupList | extendableLookup | Group | ||||
extendableLookupBO | extendableLookupList | Field | Hard code the extendable look up BO with "D1-SPInstructionLookup" | |||
extendableLookupBO | extendableLookupList | Field | Hard code the extendable look up BO with "D1-SPWarningLookup" | |||
extendableLookupBO | extendableLookupList | Field | Hard code the extendable look up BO with "D1-FieldTaskTypeLookup" | |||
Mappings for Getting Activity, Device and Register Admin Data from Oracle Utilities Customer Cloud Service | ||||||
tableName | tableList | Field | Hard code the tablename with "CI_CC_TYPE" | |||
tableName | tableList | Field | Hard code the tablename with "D1_UOM" | |||
tableName | tableList | Field | Hard code the tablename with "D1_TOU" | |||
tableName | tableList | Field | Hard code the tablename with "D1_SQI" | |||
tableName | tableList | Field | Hard code the tablename with "D1_DVC_TYPE" | |||
tableName | tableList | Field | Hard code the tablename with "D1_DVC_CFG_TYPE" | |||
tableName | tableList | Field | Hard code the tablename with "D1_SPR" | |||
tableName | tableList | Field | Hard code the tablename with "D1_MANUFACTURER" | |||
extendableLookupBO | extendableLookupList | Field | Hard code the extendable look up BO with "D1-FARemarkTypeLookup" | |||
extendableLookupBO | extendableLookupList | Field | Hard code the extendable look up BO with "D1-CancelReasonLookup" |
Oracle Utilities Service Order Management Response | Oracle Field Service Enum Request | DVM Mapping | Comments | ||||||
Element Name | Parent Element | Type | Element Name | Parent Element | Type | DVM | Oracle Field Service Column | Oracle Utilities Service Order Management Column | |
Label | Template Parameters | outermosttag | Gets the Sp property label from "SOMOFSC_Sync_ServicePointData" lookup and assigns it to the element | ||||||
Request Wrapper | |||||||||
Items | Request Wrapper | List | |||||||
code | /standardLookupList/codeDescriptionList | Label | Items | Field | |||||
Active | Items | Hard code as "true" | |||||||
translations | Items | List | |||||||
language | translations | SOM_LanguageCode | OFSC_LanguageCode | SOM_LanguageCode | |||||
description | /standardLookupList/codeDescriptionList | name | translations | Field |
code | codeDescriptionList | Label | Template Parameters | outermosttag | SOMOFSC_ActivityType | OFSC_ActivityType | SOM_TaskType | ||
code | codeDescriptionList | Label | Request Wrapper | SOMOFSC_ActivityType | OFSC_ActivityType | SOM_TaskType | |||
description | codeDescriptionList | Name | Request Wrapper | ||||||
Active | Request Wrapper | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "activityType.active" | ||||
Group Label | Request Wrapper | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "groupLabel" | ||||
Default Duration | Request Wrapper | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "duration" | ||||
Time Slots | Request Wrapper | List | |||||||
Label | Time Slots | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "timeslots.label" | ||||
Colors | Request Wrapper | ||||||||
Pending | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.pending" | ||||
Started | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.started" | ||||
Suspended | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.suspended" | ||||
Cancelled | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.cancelled" | ||||
Notdone | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.notdone" | ||||
Not Ordered | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.notOrdered" | ||||
Warning | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.warning" | ||||
Completed | Colors | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "colors.completed" | ||||
Features | Request Wrapper | ||||||||
Is Teamwork Available | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.isTeamworkAvailable" | ||||
Is Segmenting Enabled | Features | Hard code the value as "false" | |||||||
Allow Move Between Resources | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowMoveBetweenResources" | ||||
Allow Creation In Buckets | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowCreationInBuckets" | ||||
Allow Reschedule | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowReschedule" | ||||
Support Of Not Ordered Activities | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfNotOrderedActivities" | ||||
Allow Non Scheduled | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowNonScheduled" | ||||
Support Of Work Zones | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfWorkZones" | ||||
Support Of Work Skills | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfWorkSkills" | ||||
Support Of Time Slots | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfTimeSlots" | ||||
Support Of Inventory | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfInventory" | ||||
Support Of Links | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfLinks" | ||||
Support Of Preferred Resources | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfPreferredResources" | ||||
Allow Repeating Activities | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowRepeatingActivities" | ||||
Calculate Travel | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.calculateTravel" | ||||
Allow To Search | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowToSearch" | ||||
Allow To Create From Incoming Interface | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.allowToCreateFromIncomingInterface" | ||||
Calculate Delivery Window | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.calculateDeliveryWindow" | ||||
Sla And Service Window Use Customer Time Zone | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.slaAndServiceWindowUseCustomerTimeZone" | ||||
Support Of Required Inventory | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.supportOfRequiredInventory" | ||||
Disable Location Tracking | Features | SOMOFSC_ActivityTypeConfigProps | Value | PropertyName | Hard code the property name as "features.disableLocationTracking" | ||||
description | codeDescriptionList | name | translations | Field |
Label | Template Parameters | outermosttag | Gets the activity data property label from "SOMOFSC_Sync_ActivityData" lookup and assigns it to the element | ||||||
Device Type Mappings | |||||||||
Label | Template Parameters | outermosttag | Gets the Device Type property label from "SOMOFSC_Sync_DeviceTypesData" lookup and assigns it to the element | ||||||
code | codeDescriptionList | Label | Items | Field | |||||
description | codeDescriptionList | name | translations | Field | |||||
Device Configuration Type Mappings | |||||||||
Label | Template Parameters | outermosttag | Gets the Device Configuration type property label from "SOMOFSC_Sync_DeviceConfigurationData" lookup and assigns it to the element | ||||||
Device Manufacturer Mappings | |||||||||
Label | Template Parameters | outermosttag | Gets the Device Manufacturer property label from "SOMOFSC_Sync_DeviceManufacturerData" lookup and assigns it to the element | ||||||
Device Model Mappings | |||||||||
Label | Template Parameters | outermosttag | Gets the Device Model property label from "SOMOFSC_Sync_DeviceModelData" lookup and assigns it to the element | ||||||
code | codeDescriptionList/childTableCodeDescriptionList/code | Label | Items | Field | |||||
description | codeDescriptionList/childTableCodeDescriptionList/code | name | translations | Field | |||||
Device Head End Mappings | |||||||||
Label | Template Parameters | outermosttag | Gets the Device Head End property label from "SOMOFSC_Sync_DeviceHeadEndSystemData" lookup and assigns it to the element | ||||||
Register UOM Mappings | |||||||||
Label | Template Parameters | outermosttag | Gets the Register UOM property label from "SOMOFSC_Sync_RegisterUOMData" lookup and assigns it to the element | ||||||
code | tableList/codeDescriptionList | Label | Items | Field | |||||
description | tableList/codeDescriptionList | name | translations | Field | |||||
Register SQI Mappings | |||||||||
Label | Template Parameters | outermosttag | Gets the Register UOM property label from "SOMOFSC_Sync_RegisterSQIData" lookup and assigns it to the element | ||||||
Register TOU Mappings | |||||||||
Label | Template Parameters | outermosttag | Gets the Register TOU property label from "SOMOFSC_Sync_RegisterTOUData" lookup and assigns it to the element | ||||||
