Migrating from OFS Test to Production Environment
Migrate the following Oracle Field Service components from test to production environment:
Properties
To migrate properties from the Oracle Field Service Test environment to Production:
1. Export the properties that have names starting with “c2m_” from Test environment and import them into the production environment.
2. Export the common_utilities_product_code property from test environment and import it into the production environment.
Note: Make sure that the properties added manually in the test environment have been successfully imported in production environment.
Example: c2m_deviceType, c2m_Service_type, c2m_ert_custom_move_act_types, c2m_device_verify_act_types
Plugins
To migrate plugins from the Oracle Field Service Test environment to production:
1. Export the Device Verification plugin from test environment and import it into production environment. Configure the plugin secure parameters with production Oracle Integration Cloud details.
2. Export the Attachments plugin from test environment and import it into the production environment.
3. Export the Unrelated Pickup plugin from test environment and import it into the production environment. Configure the plugin secure parameters with Oracle Integration Cloud production environment details.
4. Export the Service History plugin from test environment and import it into the production environment.
5. Export the Validate Completion plugin from test environment and import it into the production environment.
User Types
To migrate user types from the Oracle Field Service test environment to production, export the customized user types from the Test environment and import them into the production environment.
Glossary
To migrate glossaries from the Oracle Field Service test environment to production, export them from the test environment and import them into production environment.
