Service History Plugin in OFS
As part of the 22A release, the Service History plugin is introduced to support the service history at the Meter/Item, and Equipment level in Oracle Field Service.
Configuration
To configure a Service History plugin:
1. Navigate to Configuration > Forms and Plugins.
2. Click the
Import Plugins button to import the service history plugin provided in the package.
![Forms and Plugins page. The Import Plugins button is the second one from right to left. Forms and Plugins page. The Import Plugins button is the second one from right to left.](../CCS-OFS_SETUP_GUIDE_22B/images/odm-activity-1-forms-plugin.png)
3. Follow these steps to fill in the plugin page setting details:
![Modify Plugin page. Modify Plugin page.](../CCS-OFS_SETUP_GUIDE_22B/images/odm-activity-2-modify-plugin.png)
a. Make sure the
Available Properties tab is populated with all the properties shown below.
![Available Properties page showing the Activity and the Inventory sections, each containing several tags. Available Properties page showing the Activity and the Inventory sections, each containing several tags.](../CCS-OFS_SETUP_GUIDE_22B/images/odm-activity-3-available-properties.png)
b. Click Service History to configure the plugin.
c. On the
User Type screen configurations, select
Service History to connect it to the specific field on the UI in the
Mobility page.
![Service History is here selected, showing the visibility section. Service History is here selected, showing the visibility section.](../CCS-OFS_SETUP_GUIDE_22B/images/odm-activity-4-service-history.png)
Service History Data is supported at the Meter/Item, and Equipment level to Oracle Field Service. Hence, the end user need not configure any data on the Oracle Field Service side.
