Business Flows
The integration scope supports the following business processes:
General Ledger Extract Process (Oracle Utilities Customer Cloud Service Initiated)
This integration process is used to transfer all approved General Ledger transaction from Oracle Utilities Customer Cloud Service to Oracle ERP Financial Cloud for General Ledger for journal creation.
It is an asynchronous flow that is triggered by a schedule. Oracle Utilities Customer Cloud Service creates a GL Extract file which is picked up by the integration process and uploaded to ERP Financial Cloud. This is just a file pass through and no transformation will be done by the integration.
Make sure the GL related batch processes (GLASSIGN, GLS, C1-GLFCX) in Oracle Utilities Customer Cloud Service are run before this integration process is run.
The following diagram shows a graphical representation of the General Ledger Extract integration process.
Business Processing
This asynchronous integration process is deployed on Oracle Integration Cloud and does the following activities:
1. If the extract file is in Object Storage, it invokes the Object Storage - List Objects REST API to get the list of files to be processed. Only files that starts with the string entered in property name gl.extract.filename.prefix in the CCSERPFIN_ConfigProps Lookup are returned. Most of the time this will only be one file.
2. If there is only one file to process, the following steps are performed. Else, the steps for each file to be processed are repeated.
a. Invokes the Object Storage: Gets Object REST API to get the actual file to process.
b. Prepares the file to be uploaded to ERP Financial Cloud.
c. Use ERP Adapter Import Bulk data option with operation Journal Import to load and import the GL data into ERP Financial Cloud.
Note: Bell and email notifications are enabled for any case in the ERP Cloud Adapter. This means when the load and import process are done, bell and email notification are sent out as long as these notifications are setup in the ERP.
3. After the file is processed by the integration, it invokes the Object Storage - Rename Object REST API to rename the file just processed in Object Storage by adding a prefix to the filename. This prefix is obtained from the property name os.prefixtag.fileuploaded in the CCSERPFIN_ConfigProps Lookup.
4. Error Handling for this process.
Any errors encountered are handled by the global fault handler.
Retry Option: Rerun from Oracle Integration Cloud.
5. An optional email notification with error details are sent to the users configured in the CCSERPFIN_Email_Id lookup. Property name email.flag in the CCSERPFIN_ConfigProps Lookup must be set to 'true' to receive email notification when errors are encountered.
Technical Details
The following table describes the integration processes and the respective Oracle Utilities Customer Cloud Service and Oracle ERP Financial Cloud artifacts used in this integration process.
General Ledger Extract Process (Oracle Utilities Customer Care and Billing Initiated)
This integration process is used to transfer all approved General Ledger transactions from Oracle Utilities Customer Care and Billing to Oracle ERP Financial Cloud for journal creation.
It is an asynchronous flow triggered by a schedule. Oracle Utilities Customer Cloud Service creates a GL Extract file which is picked up by the integration process and uploaded to Oracle ERP Financial Cloud. It is just a file pass through and no transformation will be done by the integration.
Business Processing
1. If the extract file is in ‘On’ status, it invokes the FTP Adapter to get the list of files to be processed. Only files that starts with the string entered in property name gl.extract.filename.prefix in the CCSERPFIN_ConfigProps Lookup are returned. Most of the time this will only be one file.
a. Invokes the FTP Adapter to download the file to stage directory. Stage action is used to get the actual file to process.
b. Prepares the file to be uploaded to Oracle ERP Financial Cloud.
c. Use ERP Adapter Import Bulk data option with operation Journal Import to load and import the GL data into Oracle ERP Financial Cloud.
3. After the file is processed by the integration, it invokes the FTP Adapter - Move operation to rename the file just processed in Object Storage by adding a prefix to the filename. This prefix is obtained from the property name os.prefixtag.fileuploaded in the CCSERPFIN_ConfigProps Lookup.
Any errors encountered are handled by the global fault handler. Retry Option: Rerun from Oracle Integration Cloud.
Technical Details
The following table describes the integration process and the respective Oracle Utilities Customer Cloud Service and Oracle ERP Financial Cloud artifacts used in this integration process.
Account Payable Request Extract Process (Oracle Utilities Customer Cloud Service Initiated)
This integration process is used to transfer payable refund payment request from Oracle Utilities Customer Cloud Service to Oracle ERP Financial Cloud for one-time payment creation.
It is an asynchronous flow that is triggered by a schedule. Oracle Utilities Customer Cloud Service creates an AP Request Extract file which is picked up by the integration process and uploaded to Oracle ERP Financial Cloud. This is just a file pass through and no transformation will be done by the integration.
Note: Make sure the C1-APFCX batch process in Oracle Customer Cloud have been run before this integration process is run.
The following diagram shows a graphical representation of the AP Request Extract integration process.
Business Processing
1. If the extract file is in Object Storage, it invokes the Object Storage - List Objects REST API to get the list of files to be processed. Only files that starts with the string entered in property name apreq.extract.filename.prefix in CCSERPFIN_ConfigProps Lookup file are returned. Most of the time this will only be one file.
2. If there is only one file to process, it performs the following steps. Else, the steps for each file to be processed are repeated.
c. Uses ERP Adapter Import Bulk data option with operation Import Payables Payment Requests to load and import the AP refund request data into Oracle ERP Financial Cloud.
Note: Bell and email notifications are enabled for any case in the ERP Cloud Adapter. This means when the load and import process are done, bell and email notification are sent out as long as these notifications are setup in the Oracle ERP Financial Cloud.
3. After the file is processed by the integration, it invokes the Object Storage. Rename Object REST API to rename the file just processed in Object Storage by adding a prefix to the filename. This prefix is obtained from the property name os.prefixtag.fileuploaded in the CCSERPFIN_ConfigProps Lookup.
4. Error Handling for this process. Any errors encountered are handled by the global fault handler.
Retry Option: Re-run from Oracle Integration Cloud.
5. An optional email notification with error details is sent to the users configured in the CCSERPFIN_Email_Id lookup. Property name email.flag in the CCSERPFIN_ConfigProps Lookup must be set to 'true' to receive email notification when errors are encountered.
Technical Details
Account Payable Request Extract Process (Oracle Utilities Customer Care and Billing Initiated)
This integration process is used to transfer payable refund payment request from Oracle Utilities Customer Care and Billing to Oracle ERP Financial Cloud for one-time payment creation.
It is an asynchronous flow that is triggered by a schedule. Oracle Utilities Customer Care and Billing creates an AP Request Extract file which is picked up by the integration process and uploaded to Oracle ERP Financial Cloud. This is just a file pass through and no transformation will be done by the integration.
Note: Make sure the C1-APFCX batch process in Oracle Customer Care and Billing have been run before this integration process is run.
Business Processing
1. If the extract file is in ‘On-Premise’, it invokes the FTP adapter to return the list of files to be processed. Only files that starts with the string entered in property name apreq.extract.filename.prefix in the CCSERPFIN_ConfigProps lookup file are returned. Most of the time this will only be one file.
a. Invokes the FTP Adapter: Download Operation to get the actual file to process.
d. After the file is processed by the integration, it invokes the FTP Adapter. : Move operation to rename the file just processed in CCB file path by adding a prefix to the filename. This prefix is obtained from the property name os.prefixtag.fileuploaded in the CCSERPFIN_ConfigProps Lookup.
3. Error Handling for this process. Any errors encountered are handled by the global fault handler.
4. An optional email notification with error details is sent to the users configured in the CCSERPFIN_Email_Id lookup. Property name email.flag in the CCSERPFIN_ConfigProps Lookup must be set to 'true' to receive email notification when errors are encountered.
Technical Details
Account Payable Data Payment Update Process (Oracle ERP Financial Cloud Initiated)
This integration process is used to send AP refund request payment information from Oracle ERP Financial Cloud to Oracle Utilities Customer Cloud Service.
The payment information for system-generated checks to customers is generated and processed in Oracle ERP Financial Cloud and then sent to Oracle Utilities Customer Cloud Service. Only payment information that corresponds to the AP refund requests originally generated in Oracle Utilities Customer Cloud Service are sent back. The integration process updates the original AP Request in Oracle Utilities Customer Cloud Service with the details of the payment including the payment status, check number and date.
The following diagram shows a graphical representation of the AP Data Payment Update integration process.
Business Processing
This synchronous integration process is deployed on Oracle Integration Cloud and does the following activities:
1. Subscribe to Payables Payment Created Event. Oracle ERP Financial Cloud sends a signal, along with the Account payable (AP) payment information when a payment is created in the application. The integration process will only accept payments with Payment Method = 'CHECK_CCB'. This criteria is used to identify payments made to CCS specific payables.
Note: The filtering criteria for Payment Method is hardcoded to the 'CHECK_CCB' value. This payment method must exist in Oracle ERP Financial Cloud. When sending AP Request from Oracle Utilities Customer Cloud Service, the payment method of the Payables record must be 'CHECK_CCB'.
2. The payment information received from the business event does not return the paid invoice number. Invoke the Oracle ERP Financial Cloud REST API - Get Payment - Related Invoice to get the invoice number, which corresponds to the Oracle Utilities Customer Cloud Service AP Request ID.
3. Transform the Payment information payload from Oracle ERP Financial Cloud format to Oracle Utilities Customer Cloud Service format.
4. Invoke the Oracle Utilities Customer Cloud Service REST API - AP Check Request to pass the payment information to Oracle Utilities Customer Cloud Service.
5. Error Handling for this process.
6. An optional email notification with error details are sent to the users configured in the CCSERPFIN_Email_Id lookup. Property name email.flag in the CCSERPFIN_ConfigProps Lookup must be set to 'true' to receive email notification when errors are encountered.
Technical Details
Account Payable Data Payment Void Process (Oracle ERP Financial Cloud Initiated)
This integration process is used to update Oracle Utilities Customer Cloud Service AP refund request payment status to canceled status when a payment is voided in Oracle ERP Financial Cloud.
Only voided payments that corresponds to the AP refund requests originally generated in Oracle Utilities Customer Cloud Service are sent back. The integration process updates the original AP Request in Oracle Utilities Customer Cloud Service with the canceled status.
The following diagram shows a graphical representation of the AP Data Payment Void integration process.
Business Processing
1. Subscribe to Payables Payment Void Event. Oracle ERP Financial Cloud sends a signal, along with the Account payable (AP) payment information when a payment is voided in the application. The integration process will only accept void payments with Payment Method = 'CHECK_CCB'. This criteria is used to identify payments made to Oracle Utilities Customer Cloud Service specific payables.
Note: The filtering criteria for Payment Method is hardcoded to the value of 'CHECK_CCB'. This payment method must exist in ERP. When sending AP Request from Oracle Utilities Customer Cloud Service, the payment method of the Payables record must be 'CHECK_CCB'.
2. The payment information received from the business event does not return the void payment invoice number. Invoke the Oracle ERP Financial Cloud REST API - Get Payment - Related Invoice to get the invoice number, which corresponds to the Oracle Utilities Customer Cloud Service AP Request ID.
4. Invoke the Oracle Utilities Customer Cloud Service REST API - AP Check Request to change the status of the AP request to canceled status in Oracle Utilities Customer Cloud Service.
Retry Option: rerun from Oracle integration Cloud.
Technical Details
