Type of error | Action | Notification Type | Retry |
Technical or Remote Fault Example: DACS is not accessible | Process Stop | Email | Integration fix: 1. Resend message from DERMS. |
Business Fault (DACS returns Status Not 400 or 500) | Continue Process | Collect errors and send errors in message | Data fix: 1. Resend message from DERMS. |
Business Fault (DACS returns Status 400 or 500) | Continue Process | Collect errors and send errors in Email | Data fix: 1. Resend message from DERMS. |
Technical or Remote Fault Example: DERMS is not accessible | Process Stop | Email | Integration fix: 1. Subsequent batch execution will pick up Pending messages from DACS and resend them to DERMS. |
Business Fault (DERMS returns Status Not 400 or 500) | Continue Process | Send error in message | Data fix in DACS: 1. Resend message from DACS. |
Business Fault (DERMS returns Status 400 or 500) | Process Stop | Email | Data fix in DACS: 1. Resend message from DACS. |
Technical or Remote Fault Example: DERMS is not accessible | Process Stop | Email | Integration fix: 1. Resend message from DACS. |
Business Fault (DERMS returns Status Not 400 or 500) | Process Stop | Email | Data fix in Integration: 1. Resend message from DACS. |
Technical or Remote Fault | Process Stop | Email | 1. Retry it from DERMS. 2. Fix the issue/bounce the DACS environment. |
Technical or Remote Fault Example: UCM is not accessible | Process Stop | Email | |
Business Fault (WACS returns Status Not 400 or 500) | Process Stop | Email |
Technical or Remote Fault Example: DERMS is not accessible. | Process Stop | Collect errors and send errors in email | Data Fix in DACS: 1. Rename the file in the FTP Server location in DACS by removing the “Error-” prefix in the name. 2. Reprocess the file. 3. Re-submit the error instances in Oracle Integration Cloud. |
Business Fault (DERMS returns Status 400 or 500) | Continue Process | Collect errors and send errors in email | Data Fix in DACS: 1. Rename the file in the FTP Server location in DACS by removing the “Error-” prefix in the name. 2. Reprocess the file. 3. Re-submit the error instances in Oracle Integration Cloud. |
Technical or Remote Fault Example: UCM is not accessible. | Process Stop | Email | Data Fix in DACS: 1. Rename the file in UCM by removing the “Error-” prefix in the name. 2. Reprocess the file. 3. Re-submit the error instances in Oracle Integration Cloud. |
Business Fault (DERMS returns Status 400 or 500) | Process Stop | Email | |
Business Fault (WACS returns Status 400 or 500) | Continue Process | Collect errors and send errors in Email | Data Fix in WACS: 1. Rename the file in UCM by removing the “ERROR” prefix in the name. 2. Reprocess the file. |
