DRMS (deviceStatusCheckAck: /status-check-ack-to-dacs) | DACS (ControllableDeviceStatusCheckResponse: X1-CtrlDvcStatusCheckResp) | DVM Mapping | Comments |
receiveDRMSDeviceStatusCheckAck Request Message | postDACSDeviceStatusCheckAck Request Message | DVM Name | |
dacsMessageId | responseDetail/transactionId | The “messageId” that was used in the inbound /status-check needs to be the same “messageId” from the outbound message as that's the link for DACS from the ack. | |
responseCode | responseDetail/result/status | Approved values are SUCCESS|FAILURE and are returned from DRMS after LEC check |
DACS (ControllableDeviceStatusCheckResponse: X1-CtrlDvcStatusCheckResp) | DRMS (deviceStatusCheckAck: /status-check-ack-to-dacs) | DVM Mapping | Comments |
postDACSDeviceStatusCheckAck Response Message | receiveDRMSDeviceStatusCheckAck Response Message | DVM Name | |
boStatus | MsgAck/responses/response/responseCode | SUCCESS | ERROR | FAILURE | |
communicationId | MsgAck/responses/response/dacsMessageId | ||
MsgAck/responses/response/responseTimeISO | xp20:format-dateTime (xsd:dateTime (fn:current-dateTime ()), '[Y0001]-[M01]-[D01]T[H01]:[m01]:[s01].000Z' ) | ||
MsgAck/ackType | SUCCESS | ERROR | FAILURE | ||
MsgAck/whenISO | xp20:format-dateTime (xsd:dateTime (fn:current-dateTime ()), '[Y0001]-[M01]-[D01]T[H01]:[m01]:[s01].000Z' ) |
