Input: Json Request Message with Device Reservation File, CSV Format attachment | DACS REST Web Service Name: X1-DigitalAssetEventParticipation, Operation: createDigitalAssetEventParticipation | DVM Mapping | Comments | ||
DRMS Element Name | Element Name | Parent Element | Type | DVM | |
input | Group | ||||
drmsInstanceId | OUTL-BRT-DACS_DRMS_ Routing | Identifies which NMS instance the message is coming from to route it to the appropriate DACS instance coming from the Json request message. | |||
messageId | Uniquely identifies the request message. | ||||
eventId | externalEventlIdentifier | input | Field | Comes from the Json request message. | |
eventType | eventType | input | Field | OUTL-BRT-DACS_DRMS_EventyType | Comes from the Json request message. Types: ECONOMIC or EMERGENCY |
eventStatus | Not mapped | ||||
eventStartDateTime | eventStartDateTime | input | Event start date and time Comes from the Json request message. Date should be in UTC and XSD format. | ||
eventEndDateTime | eventEndDateTime | input | Field | Event end date and time. Comes from the Json request message. Date should be in UTC and XSD format. | |
deviceList | input | List | Loops through each record in the file | ||
recordId | Uniquely identifies the record in the file. | ||||
nicId | nicId | deviceList | Field | Network Interface Controller Identifier It identifies the device. | |
headEndSystemId | headEndExternalId | deviceList | Field | Head End System Example: NEST, Ecobee, etc | |
reservationStartDateTime | reservationStartDate Time | deviceList | Field | Actual Optional Date should be in UTC and XSD format. | |
reservationEndDateTime | reservationEndDateTime | deviceList | Field | Optional Date should be in UTC and XSD format. | |
