Creating an API User
An API user configuration is required before invoking the Oracle Responsys API. This API user credentials will be used in the Oracle Integration Cloud Responsys connections to establish the connection between the Oracle Integration Cloud flow and Oracle Responsys instances.
Follow the steps provided in the Oracle Responsys Help Center for adding users. When you create an API user, assign the following roles to the user:
• Campaign Web Services Manager
• Content Web Services Manager
• Folder Web Services Manager
• List Web Services Manager
• Program Web Services Manager
• Table Web Services Manager
Note: Save the API user's username and password in a secure location. It will be used again in a future step.
