OFSC GetResourceTimeZone Request Message | DVM Mapping | Comments | ||||
Element Name | Parent Element | Type | DVM Name | Oracle Utilities Network Management System Column | Oracle Field Service Column | |
Template Parameters | OutermostTag | Resource/Get Resource | ||||
Template Parameters | Group | |||||
resourceId | Template Parameters | Group | OUTL-BRT-NMS_OFSC_ConfigProps | PropertyName | ofsc.bucket | Map the OFS bucket name from OUTL-BRT-NMS_OFSC_ConfigProps dvm |
NMS Request Message | OFS Request Message | DVM Mapping | Comments | ||||||
Element Name | Parent Element | Type | Element Name | Parent Element | Type | DVM Name | Oracle Utilities Network Management System Column | Oracle Field Service Column | |
activities | OutermostTag | bulkUpdate_POST | OutermostTag | Activity/Bulk Update Activity | |||||
activities.definitions.customActionActivityBulkUpdateSchema | bulkUpdate_POST | Group | |||||||
updateParameters | activities.definitions.customActionActivityBulkUpdateSchema | Group | |||||||
activities | activities.definitions.customActionActivityBulkUpdateSchema | List | |||||||
identifyActivityBy | updateParameters | string | Hard code with “apptNumber” | ||||||
string | |||||||||
id | activities | Number | apptNumber | activities | string | ||||
controlZone[1..10] | event | Group | |||||||
crewId | activities | String | resourceId | activities | string | OUTL-BRT-NMS_OFSC_InstanceIDToBucket | NMS_InstanceID | OFSC_BucketID | See the following figure for value date format: YYYY-MM-DD. |
date | activities | string | OUTL-BRT-NMS_OFSC_ConfigProps | PropertyName="ofsc.isScheduledForPreAssignedCrew | Value “true” | ||||
instanceId | activities | String | nms_instanceId | activities | string | ||||
type | activities | String | activityType | activities | string | OUTL-BRT-NMS_OFSC_ActivityType | NMS_ActivityType | OFSC_ActivityType | |
controlZone[1..10] | event | Group | OUTL-BRT-NMS_OFSC_ConfigProps | PropertyName="ofsc.workZone.default.FuzzyType | Value “NO_OUTAGE” | ||||
ncg | controlZone[1..10] | String | nms_control_zone_key | activities | string | OUTL-BRT-NMS_OFSC_ConfigProps | PropertyName="ofsc.controlZone | Value | If type != fuzzyType, use the incoming ncg value for that defined control_zone property. |
state | activities | String | |||||||
value | activities | String | status | activities | string | OUTL-BRT-NMS_OFSC_ActivityStatusChange | PropertyName="OFSC_ActivityStatusNew | Value | Property NMS_ActivityEventStatus equals state+value. If notfound, ignore target field. |
nms_activity_suspended | activities | string | Hardcode with 1 if status is filled | ||||||
longitude | activities/coordinates | String | longitude | activities | string | ||||
latitude | activities/coordinates | String | latitude | activities | string | ||||
String | common_utilities_product_code | activities | string | OUTL-BRT-NMS_OFSC_ConfigProps | PropertyName | Value | |||
serviceArea | activities | String | nms_serviceArea | activities | string | ||||
dispAddress | event | String | streetAddress | activities | string | ||||
comment | activities | String | nms_activity_comments | activities | string | ||||
id | event | String | nms_event_id | activities | string | ||||
active | event | String | nms_event_status | activities | string | ||||
type | event | String | nms_event_type | activities | string | OUTL-BRT-NMS_OIC_EventTypeCategoryCaching_DND | PropertyName | Second | Retrieve using NMS Event Type field. |
deviceAlias | event | String | nms_deviceAlias | activities | string | ||||
nms_deviceLocation | event | String | location | activities | string | ||||
nms_event_phases | event | String | phases | activities | string | ||||
nms_feederName | event | String | feederName | activities | string | ||||
beginTime | event | String | nms_event_beginTime | activities | string | OUTL-BRT-NMS_OFSC_ConfigProps | PropertyName | Value | Perform the date time zone conversion and format the date as configured in OUTL-BRT-NMS_OFSC_ConfigProps dvm for OFS. |
firstCallTime | event | String | nms_event_firstCallTime | activities | string | OUTL-BRT-NMS_OFSC_ConfigProps | PropertyName | Value | Perform the date time zone conversion and format the date as configured in OUTL-BRT-NMS_OFSC_ConfigProps dvm for OFS. |
restoreTime | event | String | nms_event_actualRestoreTime | activities | string | OUTL-BRT-NMS_OFSC_ConfigProps | PropertyName | Value | Perform the date time zone conversion and format the date as configured in OUTL-BRT-NMS_OFSC_ConfigProps dvm for OFS. |
value | event/ert | String | nms_event_estimatedRestoreTime | activities | string | OUTL-BRT-NMS_OFSC_ConfigProps | PropertyName | Value | Perform the date time zone conversion and format the date as configured in OUTL-BRT-NMS_OFSC_ConfigProps dvm for OFS. |
numCustOut | event | String | nms_numCustOut | activities | string | ||||
critCCustOut | event | String | nms_critCCustOut | activities | string | ||||
nms_critDCustOut | event | String | critDCustOut | activities | string | ||||
nms_critKCustOut | event | String | critKCustOut | activities | string | ||||
nms_numCalls | event | String | numCalls | activities | string | ||||
nms_userNumCustOut | event | String | userNumCustOut | activities | string | ||||
nms_weightedNumCustOut | event | String | weightedNumCustOut | activities | string | ||||
numLifeSupport | event | String | nms_numLifeSupport | activities | string | ||||
priority | event | String | nms_priority | activities | string | ||||
description | event | String | nms_event_desc | activities | string | ||||
troubleCodeDesc | event | String | nms_event_troubleCodeDesc | activities | string | ||||
cause | event | String | nms_event_cause | activities | string | ||||
jobComments | event | String | nms_event_jobComments | activities | string | Use the function get-content-as-string to read the content of the element. | |||
dispAddress | event | String | nms_event_dispAddress | activities | string | ||||
daStatus | event | String | nms_event_daStatus | activities | string | ||||
troubleQueue | event | String | nms_event_troubleQueue | activities | string | ||||
latitude | event/coordinates | String | nms_event_latitude | activities | string | ||||
String | nms_activity_ofscupdate | activities | string | Hard code with “0” | |||||
String | nms_event_category | activities | string | Map the $category variable | |||||
nms_event_incidents1 | activities | string | Map the variable $incidents_node/icd_text[1] | ||||||
nms_event_incidents2 | activities | string | Map the variable $incidents_node/icd_text[2] | ||||||
nms_event_incidents3 | activities | string | Map the variable $incidents_node/icd_text[3] | ||||||
nms_event_incidents4 | activities | string | Map the variable $incidents_node/icd_text[4] | ||||||
nms_event_incidents5 | activities | string | Map the variable $incidents_node/icd_text[5] | ||||||
longitude | event/coordinates | String | nms_event_longitude | activities | string | ||||
v[2] | event/eventDetails/details/value | String | {concat('nms_', $category, '_', lower-case(nssrcdfl:name))} | activities | string | The OFSC element will be created as part of admin sync and the element name is combination of nms_category_name. If v[1] is java.sql.TimeStamp, then convert v[2] into OFS-DateFormat. | |||
v[2] | event/failedEquipment/fields/value | String | {concat('nms_', nssrcdfl:name)} | activities | string | The OFSC element will be created as part of admin sync and the element name is combination of nms_name. If v[1] is java.sql.TimeStamp, then convert v[2] into OFS-DateFormat. | |||
position | activities | string | OUTL-BRT-NMS_OFSC_ConfigProps | PropertyName="ofsc.setPositionInRoute | Value “notOrdered” | ||||
/orders | |||||||||
QueryParameters | Activity/Search Activity | ||||||||
searchInField | QueryParameters | String | Hard code “nms_event_id” | ||||||
id | event | String | searchForValue | QueryParameters | String | ||||
dateFrom | QueryParameters | String | Use the current-date function. Subtract -21days Format the date: YYYY-MM-DD | ||||||
dateTo | QueryParameters | String | Use current-date function Format the date: YYYY-MM-DD | ||||||
/orders/complete | |||||||||
searchInField | QueryParameters | String | “apptNumber” | ||||||
id | actvities | String | searchForValue | QueryParameters | String | ||||
dateFrom | QueryParameters | String | Use the current-date function and format the date. | ||||||
dateTo | QueryParameters | String | Use the current-date function and format the date. | ||||||
offset | QueryParameters | String | “0” | ||||||
limit | QueryParameters | String | “100” | ||||||
NMS Request Message | OFSC GetActivity Data Request Message | DVM Mapping | Comments | ||||||
Element Name | Parent Element | Type | Element Name | Parent Element | Type | DVM Name | Oracle Utilities Work and Asset Management Column | Oracle Field Service Column | |
canonical_GET | Outermosttag | GET getActivityDetails | |||||||
Template Parameters | canonical_GET | Group | |||||||
externalId | actvities | String | activityId | TemplateParameters | String | ||||
NMS Request Message | OFSC Request Message | DVM Mapping | Comments | ||||||
Template Parameters | Activity/Replace Activity Link | ||||||||
activityId | $searchResult/items | activityId | TemplateParameters | String | |||||
activityId | $activityResponse Data/otherData | linkedActivityId | TemplateParameters | String | |||||
activities.linktype | linkType | TemplateParameters | String | OUTL-BRT-NMS_OFSC_ConfigProps | PropertyName | Value | |||
NMS Request Message | OIC NMS-OFS CommonErrorHandler Request Message | DVM Mapping | Comments | ||||||
POST | OutermostTag | ||||||||
request-wrapper | POST | Group | |||||||
faultMessage | request-wrapper | Group | “Data Issue” | ||||||
reason | faultMessage | Field | |||||||
code | faultMessage | Field | |||||||
instanceId | instanceId | faultMessage | Field | From runtime values | |||||
syncErrorApp Name | faultMessage | Field | OUTL-BRT-NMS_OFSC_ConfigProps | notification.type. | Value | ||||
$errorVar | details | faultMessage | Field | ||||||
notificationTypes | faultMessage | Field | |||||||
type | faultMessage | Field | “Business” | ||||||
flowname+version | flowName | faultMessage | Field | from runtime values | |||||
NMS Request Message | OIC Activity Async Processor Request Message | DVM Mapping | Comments | ||||||
Element Name | Parent Element | Type | Element Name | Parent Element | Type | DVM | Oracle Utilities Network Management System Column | Oracle Field Service Column | |
execute | Outermost Tag | executeResponse | OutermostTag | ack | |||||
request_wrapper | execute | Group | request_wrapper | POST | Group | ||||
header | request_wrapper | Group | errors | request_wrapper | Group | ||||
error | errors | List | |||||||
value | error | Field | |||||||
id | error | Field | |||||||
errorCode | error | Field | |||||||
errorTime | error | Field | |||||||
Message Id | header | Field | Message Id | request_wrapper | Field | ||||
Ack Type | request_wrapper | Field | “SUCCESS” | ||||||
When | request_wrapper | Field | Current datetime in Z format | ||||||
ConnectivityProperties | execute | ||||||||
Plugin | ConnectivityProperties | ||||||||
instanceId | ConnectionId | Plugin | OUTL-BRT-NMS_OFSC_InstanceIDToBucket | NMS_InstanceID | Retrieve NMS instance | ||||
On Error | |||||||||
FaultObject | OIC Activity Async Processor Request Message | DVM Mapping | Comments | ||||||
executeResponse | OutermostTag | ||||||||
FaultObject | Outermost Tag | ||||||||
errorCode | request_wrapper | POST | Group | ||||||
reason | errors | request_wrapper | Group | ||||||
details | error | errors | List | Fault details | |||||
errorCode | error | Field | “ERROR” | ||||||
errorTime | error | Field | Current datetime in Z format | ||||||
Message Id | request_wrapper | Field | |||||||
Ack Type | request_wrapper | Field | “ERROR” | ||||||
instanceId | BaseURI | Plugin | OUTL-BRT-NMS_OFSC_InstanceIDToBucket | NMS_InstanceID | Retrieve NMS instance | ||||
topLevelArray | OutermostTag | bulkUpdate_POST | OutermostTag | Activity/Bulk Update Activity | |||||
identifyActivityBy | updateParameters | string | apptNumber | ||||||
ifInFinalStatus Then | updateParameters | string | doNothing | ||||||
ifExistsThenDo NotUpdateFields | updateParameters | string | |||||||
resourceId | activities | string | |||||||
accessSchedule | activities | string | |||||||
resourceInternalId | activities | integer | |||||||
date | activities | string | |||||||
id | activities | Field | apptNumber | activities | string | ||||
status | activities | string | $varState | ||||||
nms_cancelledby | activities | string | “NMS” | ||||||
NMS Request Message | OIC NMS OFS Attachment Request Message | DVM Mapping | Comments | ||||||
activities | OutermostTag | POST | OutermostTag | ||||||
header | request_wrapper | Group | header | request_wrapper | Group | ||||
Message Id | header | Field | Message Id | header | Field | ||||
timestamp | header | Field | timestamp | header | Field | ||||
event | request_wrapper | Group | event | request_wrapper | Group | ||||
attachments | event | Group | attachments | event | Group | For each attachment | |||
reportType | attachments | Field | reportType | attachments | Field | ||||
fileName | attachments | Field | fileName | attachments | Field | ||||
reportId | attachments | Field | reportId | attachments | Field | ||||
length | attachments | Field | length | attachments | Field | ||||
description | attachments | Field | description | attachments | Field | ||||
fileModifiedDae | attachments | Field | fileModifiedDae | attachments | Field | ||||
documentId | attachments | Field | documentId | attachments | Field | ||||
contentType | attachments | Field | contentType | attachments | Field | ||||
uri | attachments | Field | uri | attachments | Field | ||||
id | event | Field | id | event | Field | ||||
activities | request-wrapper | Group | activities | request-wrapper | Group | ||||
id | event | Field | eventIdx | activities | Field | ||||
externalId | activities | Field | externalId | activities | Field | Use incoming or response from OFS BulkUpdate response | |||
id | activities | Field | id | activities | Field | ||||
instanceId | activities | Field | nms-instance | activities | Field | ||||
