OIC NMS Attachments Request Message | OFS findActivtyId Request Message | DVM Mapping | Comments | ||||||
Element Name | Parent Element | Type | Element Name | Parent Element | Type | DVM Name | NMS Column | OFS Column | |
request_wrapper | POST | Group | QueryParameters | Activity: Search Activity | |||||
event | request_wrapper | Group | searchInField | QueryParameters | Field | Hard code “nms_event_id” | |||
id | event | Field | searchForValue | QueryParameters | Field | ||||
fields | QueryParameters | Field | Hardcoded with “apptNumber,activityId” | ||||||
dateFrom | QueryParameters | Field | Use current-date function Subtract -21days Format the date YYYY-MM-DD | ||||||
dateTo | QueryParameters | Field | Use current-date function Format the date YYYY-MM-DD | ||||||
offset | QueryParameters | Field | 0 | ||||||
limit | QueryParameters | Field | 10 | ||||||
OFSC findActivtyId Request Message | OFS Get ActivityDetails Request Message | DVM Mapping | Comments | ||||||
request_wrapper | POST | Group | canonical_GET | Outermosttag | Activity: Get Activity | ||||
activities | request_wrapper | Group | Template Parameters | canonical_GET | Group | ||||
externalId | activities | Field | activityId | TemplateParameters | Field | If incoming externalId is empty, retrieve from findActivityId response | |||
OIC NMS Attachments Request Message | OFS deleteExistingNMSAttachment Request Message | DVM Mapping | Comments | ||||||
request_wrapper | POST | Group | canonical_GET | Outermosttag | DELETE /rest/ofscCore/v1/activities/{activityId}/{propertyLabel} | ||||
activies | request_wrapper | Group | TemplateParameters | canonical_GET | Group | ||||
externalId | activities | Field | activityId | TemplateParameters | Field | If incoming externalId is empty, retrieve it from the findActivityId response. | |||
OFSC getActivityDetails Request Message | |||||||||
request_wrapper | POST | Group | |||||||
activities | request-wrapper | Group | |||||||
nms_sourced_attachment_[1..10] | activities | Field | propertyLabel | TemplateParameters | Field | Loop through all existing nms_sourced_attachment_x fields found in the OFS GetActivity Response message. | |||
OIC NMS Attachments Request Message | NMS GetNMSAttachment Request Message | DVM Mapping | Comments | ||||||
request_wrapper | OutermostTag | execute | OutermostTag | GET /nms-ofs/rest/v1/events/{id}/attachments/{attachmentName} | |||||
event | request_wrapper | Group | HTTPHeaders | execute | Group | ||||
StandardHTTPHeaders | HTTPHeaders | Group | |||||||
Accept | StandardHTTP Headers | Field | Hardcoded to “*/*” | ||||||
Template Parameters | execute | Group | |||||||
id | event | id | |||||||
attachments | event | Group | |||||||
fileName | attachments | Field | att_name | ||||||
ConnectivityProperties | Group | ||||||||
RestAPI | ConnectivityProperties | Group | |||||||
nms_instanceId | attachments | Field | BaseURI | RestAPI | Field | OUTL-BRT-NMS_OFSC_InstanceIDToBucket | NMS_InstanceID, NMS_InstanceURL | ||
OIC NMS Attachments Request Message | OFS storeOFSAttachment Request Message | DVM Mapping | Comments | ||||||
request_wrapper | OutermostTag | put | OutermostTag | Activity: Set File Property | |||||
event | request_wrapper | Group | HTTPHeaders | put | Group | ||||
attachments | StandardHTTPHeaders | HTTPHeaders | Group | ||||||
fileName | attachments | Field | Content-Disposition | concat(“attachment;filename=”,filename) | |||||
contentType | attachments | Field | Content-Type | ||||||
activities | request_wrapper | TemplateParameters | put | Group | |||||
propertyLabel | TemplateParameters | Field | “nms_sourced_attachment_[1..10]” | ||||||
NMS getNMSAttachment Response Message | |||||||||
executeResponse | OutermostTag | ||||||||
streamReference | executeResponse | streamReference | put | Field | |||||
request_wrapper | POST | Group | canonical_GET | Outermosttag | /rest/ofscCore/v1/activities/{activityId}/{propertyLabel} | ||||
externalId | activities | Field | activityId | TemplateParameters | Field | If incoming externalId is empty, retrieve it from findActivityId response. | |||
OFS getActivityDetails Request Message | |||||||||
nms_attachment_[1..10] | activities | Field | propertyLabel | TemplateParameters | Field | ||||
request_wrapper | POST | Group | update_PATCH | Outermosttag | /rest/ofscCore/v1/activities/{activityId}/{propertyLabel} | ||||
activies | request_wrapper | Group | Template Parameters | update_PATCH | Group | ||||
updateActivity Schema | update_PATCH | Group | |||||||
nms_attach_output | activities | Field | nms_attach_output | updateActivity Schema | Field | Content with removed attachment details was deleted. Content is stored as plaintext XML with no namespaces. | |||
