New Features Summary
This integration includes the following features:
Activity Management
Activity Management integration will send status updates from Oracle Field Service to Oracle Utilities Network Management System. The following activities updates are supported in this flow:
• Activity Updated
• Activity Moved
• Activity Started
• Activity Suspended
• Activity Not Done
• Activity Cancelled
• Activity Completed
Any activity changes in Oracle Field Service will be synchronized to Oracle Utilities Network Management System and the corresponding event details will be updated.
The Activity Management feature also includes the following activity updates from Oracle Utilities Network Management System to Oracle Field Service:
• Create/Update/Cancel activities
• Preassigned Activities are also supported and provide the Oracle Utilities Network Management System operator with the ability to pre-assign crews to specific activities in the Oracle Utilities Network Management System, then pass the assignment information to Oracle Field Service, which would in turn dynamically assign the Oracle Field Service crew to the new activity, without the need to dispatcher involvement.
Note that the support for standard trouble activities (switching and damage assessment activities) is not included in this release.
Activity Created (Pick Up Orders)
The Activity Created process will send activity creation requests (Pick Up orders) from Oracle Field Service to Oracle Utilities Network Management System.
Event Details Updates
The Event Details Updates process will send event details form data from Oracle Field Service to Oracle Utilities Network Management System.
Failed Equipment Updates
The Failed Equipment Updates feature retrieves the activity details information from Oracle Field Service and the parsed failed equipment data will be updated to Oracle Utilities Network Management System.
'Crew' Sync & Status Update
The Crew Sync & Status Update feature ensures that both systems, Oracle Field Service and Oracle Utilities Network Management System, use the same resource data when communicating. For any resource creation - and update(s) - changes in Oracle Field Service, the Crew Sync process will send a synchronization request to the Oracle Utilities Network Management System to ensure data consistency. This feature also triggers updates to Oracle Utilities Network Management System when a resource is activated/deactivated in Oracle Field Service.
The Attachments feature enables both the Operator and Field Crews to seamlessly attach and share documents and media pertinent to the event.
Examples: damage reports, photos of damaged equipment, offline notes, etc.
Admin Sync
This integration process is used to sync the Oracle Utilities Network Management System admin data to Oracle Field Service. The sync will ensure that both systems are using the same data when communicating. At a high-level, this Admin Sync process runs through 10 sub-processes to sync the following Oracle Field Service data:
• Event Category “PickList”
• FailedEquipment
• Phases
• Manufacturers
• CrewTypes - WorkSkills
• ControlZones
• WorkZones
• EventType Category “PickListEnv”
• CustomerTypes
