Oracle Utilities Work and Asset Cloud Service | Oracle Fusion Procurement Cloud | DVM Mapping | Comments | ||||||
Element Name | Parent Element | Type | Element Name | Parent Element | Type | DVM Name | Oracle Utilities Work and Asset Cloud Service | Oracle Fusion Procurement Cloud | |
getAll | Outermosttag | ||||||||
QueryParameters | getAll | Group | |||||||
onlyData | QueryParameters | Boolean | Hardcoded as "true" | ||||||
orderBy | QueryParameters | String | Hardcoded as 'TransactionDate:desc' | ||||||
finder | QueryParameters | String | findLines | ;bindOrganizationCode= | |||||
Outermosttag | ERP_W1-RTNOUTMSResponse | Outermosttag | |||||||
components.schemas.responseDetails_response | ERP_W1-RTNOUTMSResponse | Group | |||||||
responseDetails | components.schemas.responseDetails_response | Group | |||||||
$POLineId | Field | externalId | responseDetails | String | |||||
Outermosttag | create | Outermosttag | |||||||
ReceivingReceiptTransactionRequests | create | Group | |||||||
TransactionType | ReceivingReceiptTransactionRequests | String | OUTL-BRT-WACS_FPRC_ConfigProps | PropertyName : fprc.returns.transactiontype | Value: fprc.returns.transactiontype.error | Maps PropertyName column to the respective Value Column. Do not change the values under PropertyName column. | |||
OrganizationCode | ReceivingReceiptTransactionRequests | String | OUTL-BRT-WACS_FPRC_ConfigProps | PropertyName : fprc.destination.organization.code | Value: fprc.destination.organization.code.error | Maps PropertyName column to the respective Value Column. Do not change the values under PropertyName column. | |||
ERP_W1-RTNOUTMS | Group | ||||||||
components.schemas.sendDetails_request | ERP_W1-RTNOUTMS | Group | |||||||
sendDetails | components.schemas.sendDetails_request | Group | |||||||
return | sendDetails | Group | |||||||
resourceTypeExternalId | return | String | ItemId | ReceivingReceiptTransactionRequests | Int | When (/nssrcmpr:ERP_W1-RTNOUTMS/nssrcmpr:components.schemas.sendDetails_request/ns27:sendDetails/ns54:return/ns55:resourceTypeExternalId != """") | |||
ReceiptSourceCode | ReceivingReceiptTransactionRequests | String | OUTL-BRT-WACS_FPRC_ConfigProps | PropertyName : fprc.source.code | Value : fprc.source.code.error | Maps PropertyName column to the respective Value Column. Do not change the values under PropertyName column. | |||
SourceDocumentCode | ReceivingReceiptTransactionRequests | String | OUTL-BRT-WACS_FPRC_ConfigProps | PropertyName: fprc.source.doccode | Value: fprc.source.doccode.error | Maps PropertyName column to the respective Value Column. Do not change the values under PropertyName column. | |||
purchaseOrderNumber | return | String | DocumentNumber | ReceivingReceiptTransactionRequests | String | ||||
SoldtoLegalEntityId | ReceivingReceiptTransactionRequests | Int | OUTL-BRT-WACS_FPRC_ConfigProps | PropertyName : fprc.soldtolegalentityid | Value : fprc.soldtolegalentityid.error | Maps PropertyName column to the respective Value Column. Do not change the values under PropertyName column. | |||
DestinationTypeCode | ReceivingReceiptTransactionRequests | String | OUTL-BRT-WACS_FPRC_ConfigProps | PropertyName : fprc.destinationtype.code | Value : fprc.destinationtype.error | Maps PropertyName column to the respective Value Column. Do not change the values under PropertyName column. | |||
$currentRcptReturnQuantity | Field | Quantity | ReceivingReceiptTransactionRequests | Float | |||||
unitOfPurchase | return | String | UnitOfMeasure | ReceivingReceiptTransactionRequests | String | OUTL-BRT-WACS_FPRC_UOM | WACS_UOMCode | FPRC_UOMName | Maps UOM Code between Oracle ERP Procurement Cloud (FPRC) and Work and Asset Cloud Service (WACS). |
employeeExternalId | return | String | EmployeeId | ReceivingReceiptTransactionRequests | Int | When (/nssrcmpr:ERP_W1-RTNOUTMS/nssrcmpr:components.schemas.sendDetails_request/ns27:sendDetails/ns54:return/ns55:employeeExternalId != """") | |||
OUTL-BRT-WACS_FPRC_ConfigProps | PropertyName : fprc.emp.id | Value: fprc.emp.id.error | Otherwise | ||||||
$currentRcptTransaction | Group | ||||||||
items | $currentRcptTransaction | Group | |||||||
ParentTransactionId | items | Field | ParentTransactionId | ReceivingReceiptTransactionRequests | Int | ||||
InterfaceSourceCode | ReceivingReceiptTransactionRequests | String | OUTL-BRT-WACS_FPRC_ConfigProps | PropertyName : fprc.interface.sourcecode | Value: fprc .interface.sourcecode.error | Maps PropertyName column to the respective Value Column. Do not change the values under PropertyName column. | |||
BusinessUnitId | ReceivingReceiptTransactionRequests | Int | OUTL-BRT-WACS_FPRC_ConfigProps | PropertyName : fprc.businessunit.id | Value: fprc.businessunit.id.error | Maps PropertyName column to the respective Value Column. Do not change the values under PropertyName column. | |||
CreateDebitMemoFlag | ReceivingReceiptTransactionRequests | Boolean | OUTL-BRT-WACS_FPRC_ConfigProps | PropertyName : fprc.returns.debitmemo.flg | Value: fprc.returns.debitmemo.flg.error | Maps PropertyName column to the respective Value Column. Do not change the values under PropertyName column. | |||
returnLineId | return | String | ExternalSystemTransactionReference | ReceivingReceiptTransactionRequests | String | ||||
DFF | ReceivingReceiptTransactionRequests | Dff | Hardcoded as 'WACS' | ||||||
returnLineId | return | String | wacsReturnLineId | DFF | String | ||||
Outermosttag | getAll | Outermosttag | |||||||
Template Parameters | getAll | Group | |||||||
$interfaceTransactionId | Field | id | Template Parameters | String | |||||
Outermosttag | APIInvocation Error | Outermosttag | |||||||
detail | APIInvocation Error | String | Hardcoded as 'Returns cannot be made on any receipt transactions' | ||||||
400 | Field | errorCode | APIInvocation Error | String | |||||
$self | Group | errorDetails | APIInvocation Error | Group | |||||
metadata | $self | Group | |||||||
runtime | metadata | Group | |||||||
instanceId | runtime | Field | instance | errorDetails | String | ||||
errorCode | errorDetails | String | Hardcoded as '400' | ||||||
title | APIInvocation Error | String | Hardcoded as 'Bad Request Error' | ||||||
detail | APIInvocation Error | String | Hardcoded as 'There are no required receipt quantity to return' | ||||||
errorCode | APIInvocation Error | String | Hardcoded as '400' | ||||||
400 | Field | errorCode | errorDetails | String | |||||
