System Configuration
To configure the Oracle Utilities Customer Care and Billing setup for the integration:
1. Login to Oracle Utilities Customer Care and Billing.
2. Setup notification types. Refer to the Notification Types section for details.
3. Setup message senders. Refer to the Message Senders section for details.
4. Setup an external system. Refer to the External System section for details.
5. Setup Bill and Collection Event algorithms. Refer to the Bill and Collection Event Algorithms section for more details.
6. Setup feature configuration. Refer to the Feature Configuration section for more details.
7. Setup Notification Preferences Master Configuration and Oracle Utilities Customer Care and Billing Self-Service Integration. Refer to the Master Configuration section for details.
Notification Types
Define the notification types to be used in the integration process between Oracle Utilities Customer Care and Billing and Oracle Utilities Network Management System.
Note: The integration includes starter notification type templates. Additional algorithms are available to support an extended list of outbound notifications from Oracle Utilities Customer Care and Billing. See the Oracle Utilities Customer Care and Billing documentation for reference.
On the Admin menu, navigate to the Notification Type portal.
Note: For all notification types, a customer contact type can be configured on the notification type to record a record of the notification that includes notification details. To enable, this configure a unique customer contact type per notification type and specify the customer contact type on the notification type.
On the Admin menu, navigate to Add Customer Contact Type. Add a Customer Contact Type with following details:
Contact Acton is Record Notification
Add the following Oracle Utilities Network Management System notification types used for this integration:
Planned Outage Started
Outage Started
Planned Outage Restored
Outage Restored
Planned Outage Canceled
Outage Canceled
Planned Outage Estimated Restoration Time (ERT) Update
Planned Outage Scheduled
Add the following Oracle Utilities Customer Care and Billing notification types used for this integration:
Bill Due Notification
On the Admin menu, navigate to the Self-Service Task Type page. Add a Self-Service Task Type with following details:
Service Task Type Business Object: Bill Due Notification Task Type
Related Transaction Object: Bill Due Notification Task
Service Task Type Status: Active
Service Task Class: Self-Service
On the Admin menu, navigate to the Notification Type page. Add a Notification Type with following details:
Notification Type Business Object: Template-Based Subscription Notification Type
Notification Type (Legacy): Bill Due Notification
Use Service Task: Enabled
Service Task Type: Service Task Type created for Bill Due Notification
Template Data Algorithms: Bill Information Template Data
Person Contact Types
Delivery Types:
Delivery Type: Email and/or SMS
Template Name: Template Name as created in Notification Delivery System
Late Payment Notification
Service Task Type Business Object: Late Payment Notification Task Type
Related Transaction Object: Late Payment Notification Task
Notification Type (Legacy): Late Payment Notification
Service Task Type: Service Task Type created for Late Payment Notification
Delivery Types:
Template Name: Template Name as created in Notification Delivery System.
Invite User Notification
Service Task Type Business Object: Web User Invitation Task Type
Related Transaction Object: Web User Invitation Task
Suppression Criteria: Always Suppressed (C1-ALWY-SUP)
Override Delivery Information: Override Guest Delivery Information (C1OVINVGSTDI)
Template Data Algorithms: Guest Notification Template Data
Delivery Types:
Confirm Acceptance Notification
On the Admin menu, navigate to the Notification Type page. Add a DSS-T Notification Type with following details:
Notification Type Business Object: Template-Based Parent Push Notification Type
Delivery Types: Email and/or SMS
Notification Type Business Object: Template-Based Individual Push Notification Type
Parent Notification Type: Notification Type created for DSS-T notifications
Delivery Types:
Collection Notification
On the Admin menu, navigate to the Notification Type page. Add a parent Notification Type with following details:
Parent Notification Type: The Parent Notification Type created above
Template Data Algorithms: Collection Notification Template Data
Delivery Types:
Notification types can be defined as Template-Based Parent/Individual Push or Template-Based Subscription. Refer to the respective product’s online help for more information.
For Template-Based Notification Types, the Template Name defined for each Delivery Types must be a valid campaign in Oracle Responsys.
Template Parameters
Template Data algorithms defined on Notification Types send a set of key/value pairs to the external system. Additional custom Template Data algorithms can be configured on the Notification Type to add more key/value pairs.
Use the following details to configure Notification Templates in Delivery System.
Template parameters sent by Bill Information Template Data algorithm:
BILL_ID
BILL_DT
BILL_DUE_DATE
AMOUNT_DUE
CURRENCY_CODE
CURRENCY_SYMBOL
MAIN_ACCOUNT_ADDRESS
SERVICE_ADDRESS
Template parameters sent by Guest Notification Template Data algorithm:
WEB_USER_NAME
OWNER_FIRST_NAME
OWNER_LAST_NAME
GUEST_FIRST_NAME
GUEST_LAST_NAME
GUEST_EMAIL
GUEST_ACCESS_ROLE
GUEST_ACCESS_ROLE_DESCR
SERVICE_ADDRESS
Template parameters sent by Collection Notification Template Data algorithm:
ARREARS_AMOUNT
ARREARS_DATE
CURRENCY_CODE
CURRENCY_SYMBOL
SERVICE_ADDRESS
Message Senders
Define a message sender for sending Oracle Utilities Customer Care and Billing template-based notification preferences outbound messages.
On the Admin menu, navigate to the Message Sender page. Add a message sender for Oracle Utilities Customer Care and Billing template-based notification preferences with the following details:
Invocation Type: Real Time
Message Class: RTJSONSNDR (Sender for real-time HTTP / JSON messages)
MSG Encoding: UTF-8 message encoding
On the Context tab, provide the HTTP URL, Login User, Login Password, HTTP Method and HTTP Timeout to the integration layer.
External System
For Oracle Utilities Customer Care and Billing Notifications, define an external system for Oracle Utilities Customer Care and Billing template-based notification preference messages.
On the Admin menu, navigate to the External System page. Add a external system for Oracle Utilities Customer Care and Billing template-based notification preference messages.
Add an outbound message type with the following details:
Outbound Message Type: C1-TMPLNTFRQ (Template Based Notification Request)
Processing Method: Real-time
Message Sender: Template-based notification preferences message sender defined above
Date/Time Format: XSD
JSON Conversion Method: Base JSON Conversion
Define the Post Bill Completion algorithm.
1. On the Admin menu, navigate to the Customer Class page.
2. On the Controls tab, configure the following algorithm:
Post Bill Completion: Set Bill Notifications for Self-Service (WX-SSBNOTIFY)
Define the Collection Event algorithm:
1. On the Admin menu, navigate to the Algorithm page.
2. Add the Collection Event Notification algorithm with the following details:
Algorithm Type: Collection Event Notification (C1COLLEVTNOT)
Notification Type: Notification Type defined for Collection Event Notification
3. On the Admin menu, navigate to Collection Event Type for the notification.
4. Configure the Collection Event Notification algorithm in the Collection Event Algorithm field.
To setup Invite Guest User and Confirm Acceptance notifications, enable the Is CX Installed feature.
1. On the Admin menu, navigate to Feature Configuration.
2. Add or edit the General System Configuration with following options:
Is CX Installed: Y
For Oracle Utilities Customer Care and Billing notifications, define the Notification Preferences master configuration:
1. On the Admin menu, navigate to the Master Configuration portal.
2. Add or edit the Notification Preferences master configuration.
3. In the Default External Communication section, add the Default External System and Default Outbound Message Type as defined above for template-based notification messages. External System and Outbound Message Type can also be configured separately for each notification type in the Override External Communication section.
Define the Oracle Utilities Customer Care and Billing Self-Service Integration master configuration:
2. Add or edit the Oracle Utilities Customer Care and Billing Self-Service Integration master configuration. Refer to the product specific online and embedded help for more information on defining each section.
3. In the Notification Service Tasks section, add the following notification types:
Bill Due Notification: Notification Type defined for Bill Due Notification
Late Payment Notification: Notification Type defined for Late Payment Notification
4. In the Guest User Invitation Notification Types section, add the following notification types:
Invite User: Notification Type defined for Invite Guest Notification
Confirm Acceptance: Notification Type defined for Confirm Acceptance Notification
