Error Handling
This section provides information on how to handle integration errors, and how to resubmit the instances after rectification.
Error Handling Procedures
For this integration, the errors are handled in Oracle Integration Cloud through the following procedures:
Synchronous Flow Error Handling
This error handler sends back the errors to the corresponding source system in the same flow.
Technical Fault
This fault occurs in case of data mismatch in DVM, or any Xpath-related error. When this error occurs, the flow immediately turns to the global fault handler, and the fault is sent back to the respective system.
Remote Fault
This fault occurs when there is a connectivity issue. When this occurs, the flow immediately turns to the global fault handler, and the fault is sent back to the respective system.
Business Fault
This fault occurs in case of an invalid data error in the target system. When this occurs, the fault is thrown to the respective source system.
Asynchronous Flow Error Handling
Technical Fault
This fault occurs in case of data mismatch in DVM, or any Xpath-related error. When this error occurs, the flow immediately turns to the global fault handler, and an optional email can be sent to the user.
Remote Fault
This fault occurs when the target system is down. When this error occurs, the flow immediately turns to the global fault handler, and an optional email can be sent to the user.
Business Fault
This fault occurs in case of an invalid data business fault in the target system. When this occurs, the flow immediately turns to the global fault handler, and an optional email can sent to the user.
Summary of Integration Error Handling
Integration Process: Oracle Utilities OCI Stream linkChannel
Type of Error
Action
Notification Type
Retry
Source Stream is down
The process is not invoked.
No Notification
Once Source Stream is up, the poller picks up the messages on the stream run.
Technical or Remote (CCB or Target Stream is unreachable)
Message is published to Source Stream (Rolling back the messages)
Email (optional)
Poller picks up the messages on the next run.
Note: Inactivate this integration process until all applications (CCB, Stream) are up to avoid the continuous reprocessing of messages that would fail.
Integration Process: Oracle Utilities NMS OCI Stream Notif Upload
Type of Error
Action
Notification Type
Retry
NMS DB down/unavailable
Executes Select/Update to table MYC_CSS_PARAM_VIO_TEXT from NMS DB
Email
Restart programmed schedule once the issue is resolved.
Technical or Remote (Source OCI Stream is unreachable)
The only error scenarios expected are technical errors while accessing OCI Stream, such as: password expired, certificates expired. The expectation of OCI Stream API call is rare programmed schedule must be paused.
Email
Once fixed OCI Stream connectivity restart scheduled integration.
Technical or Remote (OIC API Connection is unreachable)
This will have an impact as integration will not have a chance to trigger another batch of data and will wait until next schedule run.
Email
NMS Parse data from String to XML
This is a rare scenario since standard xpath function is used parseXML() to parse string to XML format, MYC_CSS_PARAM_VIO_TEXT is updated with CSS_NOTIFIED='E'.
Email
From NMS Flag from CSS_NOTIFIED needs to be updated from 'E' to 'N' to be reprocessed.
Convert XML format to JSON format
This is a rare scenario since it uses standard mapping. MYC_CSS_PARAM_VIO_TEXT is updated with CSS_NOTIFIED='E'.
Email
Integration Process: Oracle Utilities Responsys CCB Cust Contact Create
Type of Error
Action
Notification Type
Retry
400 or 500 error status when CCB Create Customer Contact API is invoked
As part of the CED/Pending file processing, in the message collection, each errored record or message is captured. After reaching the max error count, an email with the details of the failed records is sent.
Email is sent with errored details for each CED/Pending file type. Also, in the global fault handler, an error email notification is sent if the notification flag is turned on.
Reprocessing happens on the next schedule job process.
Not 400 or 500 error status when CCB Create Customer Contact API is invoked but other status code except 200.
For example: 403, 401 error code
The integration process will be stopped, and no further messages will be processed from the file.
In global error handler scope, an email notification will be sent if notify error flag is turn on.
To retry (for example: 401) passwords expired, does not make sense, hence should not be retried in this scenario. After fixing the expired password, the flow can be scheduled again.
Oracle Responsys SFTP server being down/unreachable
The integration will not pick any files for further processing.
Reschedule the parent process in integration process (Oracle Utilities Responsys CED Process).
Integration Process: Oracle Utilities Responsys CED Process
Type of Error
Action
Notification Type
Retry
Oracle Utilities Responsys CCB Cust Contact Create integration service is unavailable
API call will be failed and CED file will be processed. The process is terminated.
Reschedule the integration process.
Integration Process: Oracle Utilities Responsys SFTP File Create
Type of Error
Action
Notification Type
Retry
Responsys SFTP server being down/unreachable.
The integration will put back the consumed message in OCI stream.
OCI message will be consumed automatically on next schedule run.
OCI stream down/unreachable
Email is sent.
Integration Process: Oracle Utilities OCI Stream Responsys Notif Send
Type of Error
Action
Notification Type
Retry
Not 401 or 500 error status when Responsys API is invoked
Error messages from each invoke in a batch for a particular Oracle Responsys instance, along with account ID, template name and delivery channel is collected in a collection.
A separate email is sent for errors in each Oracle Responsys instance.
These notification messages cannot be recovered.
Error status that is 500 or 401 when Responsys API is invoked
A separate email is sent with error collection of each Responsys instance.
These notification messages are republished back to TargetNotificationStream, until the issue is resolved.
Note: If the resolution takes a while, inactivate the process to avoid receiving emails and republishing.
Technical or Remote (TargetNotificationStream OCI Stream is unreachable)
During polling, if the OCI Stream is unreachable, the OIC instance is not instantiated.
Email (optional)
Poller will pick up the messages on next try.
Invalid delivery channel or Oracle Responsys instance
An email is sent with the error collection for each batch.
Integration Process: Oracle Utilities CCB OCI Stream Notif Upload
Type of Error
Action
Notification Type
Retry
Technical or Remote (Target Stream is unreachable)
• Fault is logged in the OIC Instance.
• Fault is rethrown to Global handler.
No Notification
CCB must resend the notification outbound message to OIC.
Any Global
Fault is rethrown back to CCB.
Email (Optional)
Integration Process: Oracle Utilities Responsys CCB Pref Unsubscribe
Type of Error
Action
Notification Type
Retry
Business Error when processing records in file
The errors are collected in an error collection and the processing continues.
An email notification is sent when error count reaches the max.error.count defined in the configuration lookup.
Based on the errors in the error notification email any updates to the record is done manually.
Technical or Remote (CCB or SFTP location is unreachable)
Global fault is thrown
Email (optional)
Reschedule the process once the issue is resolved.
Integration Process: Oracle Utilities CCB Notif MetaData Sync
Type of Error
Action
Notification Type
Retry
Source Stream (CCB) is down
Email notification (if configured)
On Error, run the integration again.
Technical or Remote fault
OCI Rest call to create/modify DVM api
Resubmitting the Error Instances in Oracle Integration Cloud
The resubmit option is only available for asynchronous flows, as are all the flows initiated by Oracle Utilities Network Management System for this integration.
To resubmit the error instances in Oracle Integration Cloud:
1. Log in to Oracle Integration Cloud.
2. Navigate to Integrations > Monitoring > Errors.
3. Select the integration to resubmit.
4. Click the Resubmit icon.
Note: Retry or Resubmission error instance from the OIC Monitoring page may not be applicable for the Oracle Utilities NMS OCI Stream Notif Upload integration flow. Refer to the Summary of Integration Error Handling section on how to retry/resubmitted errored transactions/record.
