Using the Sample Form
The base OU_Campaigns.zip provided has a sample form Intg_Unsubscribe. Copy this form to the required folder (example: CM_OU_CAMPAIGN) with a different name.
Important! Make sure to rename the form with a different name while copying it into the CM folder. Not doing so will cause a conflict when importing OU_Campaigns.zip in the subsequent releases.
1. Select and right-click
Intg_Unsubscribe sample form. From the menu, select
Form Dashboard to open the form dashboard.
![Select Form Dashboard to open the form dashboard. Select Form Dashboard to open the form dashboard.](../NH-SETUP-GUIDE-23A/images/select-form-dashboard-chap4.png)
2. Click
Name and update the form name and destination folder.
![Shows how to update the form name and destination folder. Shows how to update the form name and destination folder.](../NH-SETUP-GUIDE-23A/images/update-name-and-destination-folder-chap4.png)
4. Point the Form Document to “Unsubscribe_Confirm.htm”.
5. Update
Form Rules and set the
Landing Page.
![](../NH-SETUP-GUIDE-23A/images/update-form-rules-chap4.png)
6. Update
Form Rules to select the supplemental table.
![](../NH-SETUP-GUIDE-23A/images/update-form-rules-supplemental-table-chap4.png)
7. Specify Default Variables as shown below. By default, the data sent to form is base64 encoded.
Define the following variables, initializing with null value ($nothing()$) where appropriate:
• contact_value
• account_id
• notif_pref_id
• contact_id
• notif_type
• notif_desc
• unsub_pk
Default value: $base64encode(concat(lookup(contact_value),todayformat(0,yyyy-MM-dd HH:mm:ss:S)))$ )
• contact_type
Default value: $base64encode(email)$)
8. Enable the form.
![Shows how to enable the form. Shows how to enable the form.](../NH-SETUP-GUIDE-23A/images/enable-the-form-chap4.png)
