Monitoring from the Integration Layer
To monitor the integration flow, use any of the following method:
Monitoring Integration Flows from Oracle Integration Cloud Dashboard
On the Oracle Integration Cloud dashboard, you can view how the running integrations process messages, such as:
•	Messages received and processed
•	Successful messages and errors occurred
•	Overall success rate
Note: Only activated integrations are listed on this page.
To monitor integrations from the Oracle Integration Cloud dashboard:
1.	On the Oracle Integration Cloud Home page, click the Monitoring icon.
2.	On the navigation pane, click Dashboards to see the overall success/failure rate of the integration.
3.	On the navigation pane, click Integrations.
	A list of running integrations is shown. Also, processing information about the number of messages received, the number of messages processed, the number of successful messages, and the number of failed messages is displayed.
4.	From the In Retention Period list, select the time period for which the integration information should be displayed.
	For example: one hour, six hours, one day, two days, three days, or since the first activation
5.	From the Integrations list, select Activity Stream to view the activity stream for the integrations.
Monitoring Integration Flows using Oracle Integration Cloud Logs
To monitor integration flows using Oracle Integration Cloud logs, perform the following steps:
3.	Navigate to the Logs menu.
4.	In the right pane, click the link to show options for downloading the Oracle Integration Cloud logs or diagnostics logs.
5.	If there are issues with an integration, attach the diagnostic logs to a service request for help in debugging the issue.
