Solution Overview
The technical aspects involved in the integration between Oracle Assets and Oracle Utilities Work and Asset Cloud Service are:
• The integration layer consists of integration processes deployed on Oracle Integration Cloud.
• The integration processes interact with other applications using the following adapters:
• Oracle ERP Cloud Adapter to invoke Asset FBDIs and scheduled processes in Oracle ERP Cloud/Oracle Assets. This invokes:
• Fixed Asset Mass Additions FBDI
• Prepare Asset Transaction Data scheduled process
• Project Asset and Assignment FBDI
• Fixed Asset Mass Transfer FBSI
• Fixed Asset Mass Adjustment FBDI
• Fixed Asset Mass Retirements FBDI
• FTP adapter to interact with the Oracle Utilities Work and Asset Management FTP server to search, get, and rename the asset extract files.
• REST Adapter to interact with the Oracle Utilities Work and Asset Cloud Service Object Storage to search, get, and rename the asset extract files.
• REST Adapter to invoke ERPFA REST APIs to get the Asset Details and the Schedule Process/job status.
• REST Adapter to receive and send asset records across Oracle Integration Cloud integration flows and also used to invoke the Common Error Handler Oracle Integration Cloud integration flow.
• The integration pattern used for the solution is:
• One-way asynchronous for all flows.
• Email notification is optional in most cases. Configure the email.flag property name in the OUTL-BRT-WACS_ERPFA_CONFIGPROPS lookup to ‘true’ to receive email notification when errors are encountered. By default, this is set to ‘true’.
• The recipient(s) of the email notification is configured in the OUTL-BRT-WACS_ERPFA_EMAIL_ID lookup.
Refer to the Integration Flows section for more information about each integration process.
