Type of Error | Action | Notification Type | Retry |
Technical Fault Example: DACS is not accessible | • Send FAILURE ackType to DERMS • Process Stop | Error Email | Resend message from DERMS |
Business Fault (For Each Record Processing) (DACS enrollProgram returns - Status VAL-ERROR or ERROR) | • Set Error to record’s AckType response to DERMS • Add to DERMS AckType Collection • Process Next Record • At the end of the collection processing, send ackType Collection and ERROR ackType to DERMS | None Enrollments created in DACS DACS handles the validation errors | |
Business Fault (For Each Record Processing) (DACS enrollProgram messageNumber = 10589) | • Error means the enrollment req exist in DACS already • Ignore the error • Process Next Record | None Resend message from |
Type of error | Action | Notification Type | Retry |
Technical Fault Example: DERMS is not accessible | Process Stop | Error Email | Resend message from DACS |
Business Fault | Continue Process | Send error in message | Data fix in DACS: 1. Resend message from DACS. |
Business Fault | N/A |
Technical Fault Example: DERMS is not accessible | • Send FAILURE ackType to DERMS • Process Stop | Error Email | Resend message from DACS |
Business Fault | N/A | None |
Technical Fault Example: Source FTP or Source Object storage is not accessible | Process Stop | Error Email | Next scheduled run will pick up the files from DACS source content server or manually run the OIC process |
Partial Processing Technical Fault During Processing in Loop Example: DERMS is not accessible | Process Stop | Error Email Process Complete Email (includes list of files not transferred) | Rename the file in DACS content server by removing the “Error-‘ prefix in the filename then manually run the OIC Process |
Business errors | N/A |
Technical Fault Example: DACS storage is not accessible | • Send FAILURE ackType to DERMS • Process Stop | Error Email | Resend message from DERMS |
