Configuring Connections in Oracle Integration Cloud
After the packages are imported and verified, configure the respective connections.
This section describes the procedure to configure the following:
OU REST DACS for DACS-DRMS Connection
This connection is used to communicate with Oracle Utilities Digital Asset Cloud Service using the Utilities adapter.
To configure the OU REST DACS for DACS-DRMS connection:
1. Login to Oracle Integration Cloud and navigate to the connection.
2. Add the Oracle Utilities Digital Asset Cloud Service catalog URL in the Catalog Url element.
3. Select Basic Auth on the Security tab and enter the Oracle Utilities Digital Asset Cloud Service user name and password.
OU REST DRMS for DACS-DRMS Connection
This connection is used to communicate with Oracle Utilities Grid Edge Distributed Energy Resources Management System application service using the Utilities adapter.
To configure the OU REST DRMS for DACS-DRMS connection:
2. Add the Oracle Utilities Grid Edge Distributed Energy Resources Management System catalog URL in the Catalog Url element.
3. Select Basic Auth on the Security tab and enter the Oracle Utilities Grid Edge Distributed Energy Resources Management System user name and password.
OU REST for DACS-DRMS Connection
This connection is used to call integrations using the basic REST adapter.
To configure the OU REST for DACS-DRMS connection:
2. Select Basic Auth on the Security policy tab.
3. Click Test and Save the connection.
OU FTP DACS for DACS-DRMS Connection
This connection is used to communicate with Oracle Utilities Digital Asset Cloud Service FTP Service using the FTP adapter.
To configure the OU FTP DACS for DACS-DRMS connection:
2. Set the FTP Server Host Address (xxxx.com).
3. Do not modify anything on the FTP Server port and SFTP connection tabs.
4. Select the FTP Server Access policy on the Security policy tab and enter the Oracle Utilities Digital Asset Cloud Service FTP Server username and password.
Note: Make sure the FTP Server is setup and configured in Oracle Utilities Digital Asset Cloud Service.
OU REST DRMSSVC for DACS-DRMS Connection
This connection is used to communicate with Oracle Utilities Grid Edge DERMS application service using the REST adapter.
To configure the OU REST DRMSSVC for DACS-DERMS connection:
2. Add the Rest Connection URL in the Connection URL element.
3. Select Basic Auth on the Security policy tab and enter the Oracle Utilities Grid Edge Distributed Energy Resources Management System username and password.
OU REST DACS Object Storage for DACS Connection
This connection is used to communicate with Oracle Infrastructure Cloud Object Storage Services using the REST adapter.
To configure the OU REST DACS Object Storage for Oracle Utilities Digital Asset Cloud Service connection:
1. In the Connection Properties section, enter the object storage API endpoint in the Connection URL field.
The Connection URL follows this format: https://objectstorage.{region}.oraclecloud.com
Refer to the Oracle Cloud Infrastructure documentation/API Reference and Endpoints to see the Object Storage Service API and endpoints at:
2. In the Security section:
a. Select the OCI Signature Version 1 security policy.
b. Provide the following Object Storage information:
• Tenancy OCID
• User OCID
• Upload the private key
• Fingerprint (obtained from object storage after register the public key for the appropriate user)
3. After the connection is tested successfully, click Save.
