Type of error | Action | Notification Type | Retry |
Technical or Remote Fault Example: OUAI object storage is not accessible | • Send FAILURE ackType to DERMS • Process Stop | Email | Resend message from DERMS |
Business Fault | N/A |
Business errors | N/A | ||
Technical Fault Example: Source FTP or Source Object storage is not accessible | Process Stop | Error Email | Next scheduled run will pick up the files from DACS source content server or manually run the OIC process |
Partial processing Example: Network connection issue, OUAI object storage not accessible | Process Stop | Error Email Process Complete Email (includes list of files not transferred | Next scheduled run will pick up the files not transferred from DACS source content server or manually run the OIC process |
Technical Fault Example: OUAI object storage is not accessible | • Send FAILURE ackType to DERMS • Process Stop | Error Email | Resend message from DERMS |
Technical or Remote Fault Example: OUAI object storage is not accessible | Process Stop | Error Email | Rerun or schedule the integration process |
Business Fault | N/A | ||
Technical Fault (DACS returns Status 401 or 500) | Process Stop | Email | Integration fix: Rerun or reschedule the integration process |
Technical Fault (DACS returns Status 400) | Process Continue | N/A | DACS throws 400 error when a duplicate request is found with syncrequestid. OIC will suppress this kind of error as this is already been sync from Oracle Utilities Analytics Insights to Oracle Utilities Digital Asset Cloud Service. |
