Configuring Connections in Oracle Integration Cloud
After the packages are imported and verified, the respective connections have to be configured.
This section describes the procedure to set up the following connections:
Configuring Oracle Utilities SOAP UCM Gen Svc for WACS-ERPFIN Connection
This connection is used to communicate with Oracle Universal Content Management using the SOAP adapter.
Configure the Oracle Utilities SOAP UCM Gen Svc for WACS-ERPFIN connection:
1. Specify the WSDL URL.
The Oracle UCM Web Service follows this format: https://{ERP Cloud host}/idcws/GenericSoapPort?WSDL
2. From the Security Policy drop-down list, select Basic Authentication.
3. Provide Username and Password to connect to Oracle UCM.
4. Click Test at the upper-right corner.
5. After the connection is tested successfully, click Save.
Configuring Oracle Utilities REST WACS for WACS-ERPFIN Connection
This connection is used to communicate with Oracle Utilities Work and Asset Cloud Service using the Oracle Utilities adapter.
Configure the Oracle Utilities REST WACS for WACS-ERPFIN connection:
1. Specify the Oracle Utilities Work and Asset Cloud Service REST web catalog to the catalogURL section.
The REST Catalog URL follows this format: https://{host}:{port}/{tenant}/{domain}/{appName}/rest/openapi/iws/catalog
2. In the Security Policy section, select Basic Authentication.
3. Provide Username and Password to connect to Oracle Utilities Work and Asset Cloud Service.
4. From the Security Policy drop-down list, select Basic Authentication.
5. Click Test at the upper-right corner.
6. After the connection is tested successfully, click Save.
Configuring Oracle Utilities REST WACS OS for WACS-ERPFIN Connection
This connection is used to communicate with Oracle Infrastructure Cloud Object Storage using the REST adapter.
To configure the Oracle Utilities REST WACS OS for WACS-ERPFIN connection:
1. In the Connection Properties section, enter the object storage API endpoint use by Oracle Utilities Work and Asset Cloud Service in the Connection URL.
Refer to Oracle Cloud Infrastructure Documentation/API Reference and Endpoints to see the Object Storage Service API and endpoints (https://docs.cloud.oracle.com/en-us/iaas/api/).
2. In the Security section:
a. Select the OCI Signature Version 1 security policy.
b. Provide the following Object Storage information:
Tenancy OCID
User OCID
Upload the private key
Fingerprint (obtained from object storage after register the public key for the appropriate user)
For more information, refer to the Object Storage Setup Guide 20C at:
https://docs.oracle.com/cd/F35460_01/index.htm
3. On the Connection page, enter the user name and password. Click Test.
4. After the connection is tested successfully, click Save.
Configuring Oracle Utilities ERP FIN for WACS-ERPFIN Connection
This connection is used to communicate with Oracle ERP Financial Cloud application using the Oracle ERP Cloud Adapter.
To configure the Oracle Utilities ERP FIN for WACS-ERPFIN connection:
1. Enter the ERP Services Catalog WSDL URL.
The ERP Services Catalog WSDL URL follows this format: https://{ERP Cloud host}/fndAppCoreServices/ServiceCatalogService?wsdl
2. Enter the ERP Event Catalog URL.
The ERP Event Catalog URL follows this format: https://{ERP Cloud host}/soa- infra
3. In the Security Policy section, select Username Password Token.
4. Enter the Username and Password to connect to Oracle ERP Financial Cloud.
5. Click Test.
