External System
To create a new external system to support the integration:
1. Navigate to the External System page from the Admin menu or from the Search menu.
2. Enter a unique external system and description.
For example: Name = INT_ERPPM_ES, Description = ERP Project Management External System
3. Set the Our Name in Their System field to “WACS”.
4. Associate the outbound message types and message senders created to the external system.
For each outbound message type, set the following:
• Outbound Message Type: Outbound message type for the respective integration service
• Processing Method: Real-time
• Message Sender: Set the message sender created for the integration service
• Date/Time Format: XSD
• JSON Conversion Method: Base JSON Conversion
For more information about message senders and outbound message type for each integration service, refer to the Message Senders and External System sections respectively.
